How do I reset, error code EFO on my AEG 76800
I get an error code EFO
KOakaKO
  • 135 Answers
SOURCE: flashing EFO error code
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Posted on Aug 04, 2007
SOURCE: ERROR CODE EFO
You can call or email the manufacture to find out.
Posted on May 27, 2008
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Posted on Sep 17, 2008
SOURCE: Anti-flooding system has activated.
Tip washing machine towards you, water in bottom of machine will pour out, so be ready! Should work after that, mine did!
Posted on Nov 18, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
HI, The machine displays "EFO"... We put the water out as described on your site but it seems the code "EFO" is still in memory (there is no more water inside, but each time we start a new program, the...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 15, 2010 | AEG Lavamat 88840 Front Load Washer
Tengo una lavadora aeg lavamat 72850 y me está dando error efo en la pantalla...las instrucciones me ponen que apague en aparato y llame al servicio técnico pero la garantia ya se me...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Aug 14, 2010 | AEG Lavamat 88840 Front Load Washer
Washing machine - efo error display. machine stops. bleeping sound
The code EFO shown to the user can either be related to a blockage in the filter or pump.Also check the outlet drain hose for kinks or blockages.Another one to check out is that there is not too much detergent in the drum as this causes overfoaming.
Hope this was helpful.
Aug 04, 2010 | AEG Washing Machines
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
E10 error and Efo error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!
Nov 24, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Aug 23, 2009 | AEG Washing Machines
EFO error code
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
May 15, 2009 | Kenmore 44102 Front Load Washer
EFO, E10 error Message
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
