Question about Reebok Exercise & Fitness
My Reebok v6.80 treadmill turns and lights up but won't go.
Took the hood part off and the incline motor works and moves but it's not moving the belt to make the treadmill move. The power part with cords and fuses has a red light that comes on
  • 6 Answers
SOURCE: Treadmill motor not coming on, belt not moving
most likely cause is a burnt out motor controller, you'll need to replace it.
Posted on Mar 17, 2009
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
  • 3 Answers
SOURCE: Profom frontrunner.Power,lights,no motor or incline.3yrs old.
I had the same problem-only one of my programs would work, and the rest of the buttons (even start) would not work. I used some scissors and carefully cut about a 1/2 inch in the plastic inbetween each of the copper strips in the ribbon cable. Then I seated each one individually (put them back in the white plastic thing) until I found the one that was freezing all of the other buttons up. Now all of my buttons EXCEPT for the one that was working before work. I can live without 1 program if it saves me $300
PS-mine also stopped working after we moved it, but when I told an "expert" that he said it wouldn't just stop working because I moved it....I think moving it DEFINATELY had something to do with it.
Posted on Aug 23, 2010
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
My treadmill won't start. It sounds like it is inclining when I insert the key but nothing lights and it is not moving.
Dear Sir:
Inside test the fuse and replace use DVOM, or reset the c.breaker
2) Adjust the reed switch see the diagram attached, clean,and tight the connector very well. Tigh the ribbon cable from keypad + connector from display board vs lower board
3) Lube the deck vs deck belt, this produce enough friction.
4) test the input motor voltage,if there are the motor need repair or replace
5) Test the output voltage from the m.motor board for the input motor voltage, if there are NOT the board is faulty.
6) Try after your fix, the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 01, 2012 | Proform CrossTrainer Treadmill
What could it mean if the treadmill just stops, but the board is still lit up? The belt won't move even when I turn the treadmill off and turn it back on. The numbers on the board light up, but...
Dear Sir:
I will help you, inmediately.:
Try it with this step:
When machine is Stopped with various months, the dust+ corrosion in the electronic system can be affected.do it the following :
    • 1
Someconsoles require batteries. Check to see if this is the problem. If the consoledoes not use batteries, move on to Step 2.
    • 2
Removethe key from the console.
    • 3
Unplug the power cord.
    • 4
Removethe screws from the console hood and remove the hood.
    • 5
Turnthe pulley until the reed switch and magnet are aligned with a 1/8-inch gapbetween reed switch and pulley.
    • 6
Replace the hood.
    • 7
Plugin the power cord.
    • 8
Reinsertthe key into the console.
    • 9
Runthe treadmill to check for a correct speed reading. This may take a fewminutes. Check this, and contact me, if you need some additional help. blessing , sincerely. E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Reebok Exercise & Fitness
Hello - when I turn on my reebok treadmill, the only buttons that work are start and incline (incline works most of the time). All of the other buttons do not work. Its a Reebok Vista RBTL13305 model...I...
Let me know if you find a solution. I am having the same problem and cant figure it out. It turns on and will start but none of the other buttons work. Its so frustrating.
Aug 14, 2011 | Reebok Vista Treadmill - RBTL13305
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
Feb 11, 2011 | Reebok 8000 ES Treadmill
The belt won't move and the incline is stuck. display isn't working properly either
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
Mar 01, 2010 | Reebok 8050 ES Treadmill
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Oct 25, 2009 | Reebok Rt1000 Treadmill Walking Belt
Incline problem
Make surt that there is nothing under the treadmill that could get caught in the mechanism.
Feb 05, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Brand new Reebok v6.80 treadmill, trouble on start up!
I just had the same thing happen to me with the same treadmill. I called Reebok and they had me remove the motor hood. Sure enough, the bolts holding the motor had completely sheared off and the motor was lying loose in the bottom of the treadmill. They are sending a new motor and bolts and a technician to install them. They said it was probably dropped hard during shipping.
Jan 23, 2009 | Reebok New York Giants Eli Manning Jersey
Exercise & Fitness Logo
18 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
