Question about Epson Aculaser C1100 Printer
Need to reset error code E547 on Epson AcuLaser CX11N
I have no details.
  • 163 Answers
E547 is a feed motor error, usual culprit is a faulty solenoid. You will need a technician to check all wiring & replace faulty part I'm afraid.
Posted on Feb 13, 2009
Epson Aculaser CX11N /11NF. Paper jam error will...
this could be due to the sensor at behind of the printer.. you should be able to see it once you open cover E.. it's very delicate plastic and normally when you clear the paper , you might accidently damage it.. you will need to open the read feed assy to fix it.. 4 screws and you should be able to remove it.. but first remove the E cover but slightly forcing the lower left hidge.. use a test pen...
May 20, 2010 | Office Equipment & Supplies
I have a new photoconductor unit in my epson CX11N aculaser printer and now it is printing anything in colour with a white stripe down the left hand side about 4cm in
Hi
Try taking out all toners and reinstall them. Turn on unit, without Photoconductor, wait till you get error install photoconductor. Insert photoconductor and try printing again.
Hope this helps
Mar 26, 2010 | Epson AcuLaser CX11N All-In-One Printer
Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Nov 12, 2009 | Epson AcuLaser C2600N Printer
Toner cartridge error message
try putting another cartridge even used one just to isolate the problem whether with cartridge or printer, probably a sensor not detecting the cartridge
May 26, 2009 | Epson AcuLaser CX11N All-In-One Printer
E547
E547 = Feed Motor Failure
This means that the feed motor is not turning at the correct speed - or at all. Check for problems in:
HARNESS-ASSY FEED MAIN
DRIVE ASSY FEED
PWBA TRAY 500
HARNESS-ASSY FEED 1
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Service manual is available HERE if you need it
Jul 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Full colour page print has faded lines printed through the work
I have ordered a new photocunductor unit as i am assuming that the other one was faulty.
Jul 07, 2008 | Epson AcuLaser CX11N All-In-One Printer
Paper jam and E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson.
Jun 15, 2007 | Epson Aculaser C1100 Printer
E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson. Check my previous post on this item: http://www.fixya.com/support/t154259-paper_jam_e547
Epson Aculaser C1100 Printer Logo
914 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
