Question about Sony Ericsson W200i Cellular Phone
Memory status maximum expandable capacity of w200i
I Just bought a 2 gigabyte card a week ago.Works fine but the phone just takes about 15 seconds to start but no performance problems.
Posted on Jan 11, 2009
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
My camera the mercury cyberpix 2-210s only take 20 or so pictures and has a memory card of 8 mb and I don;t understand why.
Your Mercury Cyberpix S-210S has an internal memory of 16MB and can be expanded using an SD/MMC Card up to 512MB.Since the picture you capture using this 2 Megapixel camera has an approximate resolution of 1600*1200 and a size of approximately 400kB you can store only around 18 to 20 photos in an 8MB Memory Card.So if you want to store more pictures you have to insert a Memory Card of bigger capacity.Remember the maximum Memory Card capacity supported on your camera is 512MB.Thanks for choosing Fixya.
Jun 19, 2011 | Kobian Mercury 3.1 Deluxe Classic Digital...
What is the maximum capacity of memory card of sony ericsson phone (K800i)?
The maximum limit up to which the memory can be expanded in Sony Ericsson K800i is 2GB.
Thanks for using Fixya.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 01, 2010 | Sony Ericsson K800i Cellular Phone
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Need a manual or instructions how to operate it
experimental status
ZEN mozaic player 2 GB
firmware 1.03
ZEN attached to USB 2.0
Windows XP SP2
Message "do not disconnect"
ZEN is not being recognized
Check ZEN memory setting
Memory ZEN is set to 0 in MENU>Etras>removable disk
Memory ZEN should be changed to maximum 1.5 GB
ZEN is recognized now
ZEN is ready to do the format command
ZEN can be written to for a maximum of 0.5 GB [internal memory !]
ALERT ! This 0.5 GB is the internal memory
The files written to the internal memory will be erased after
disconnecting !
access status
NO ACCES TO MY ZEN ?
1) Get access to ZEN by setting disk memory to maximum
2) ZEN should be recognized now
format status
1) FORMAT the disk
After formatting !
SET BACK YOUR disk memory capacity to zero [ 0 ]
for fully recovering the disk capacity
files presence status
FILES NOT PRESENT AFTER DISCONNECTING ?
- When set to zero you can use the full memory for
writing files to the player !
- When keeping the memory set to maximum you're using
the internal memory and written files are not saved
after disconnecting
updating + files presence status
UPDATING FIRMWARE ZEN MOZAIC = MAKING STANDARD MAPS
1) download the firmware that is suited for your computer
Operating System and your type of player from "CREATIVE"
2) Connect player to USB 2.0
and update with the firmware-update
3) Wait until the update is fully completed
4) After the update disconnect the player
5) Connect to USB 2.0 again
6) Check for the presence of the STANDARD MAPS for Music,
Pictures and Video
7) Files can be written into the STANDARD MAPS
8) Written files should be present after disconnecting
9) Files ready for mobile playing on ZEN mozaic now
CREATIVE support site for fimware / software / userguide
SUPPORT FOR ZEN MOZAIC ON THE INTERNET
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
May 10, 2009 | Creative Labs Creative Technology Zen MP3...
Inbox memory of w200i
It can store up to 177 sms messages.
Mar 13, 2008 | Sony Ericsson W200i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
61 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
