Question about Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I connected the 360 to the Mitsubishi HDTV using the HDMI cable that came with the Xbox. No picture, at all. Tried using the HD AV cable. Same result, no picture. What am I missing? Do I need to program the console to have an HDMI output? Or is there something wrong with the Xbox? Help, my kids are driving me crazy!!! Thank you.
  • jhogue Apr 27, 2008
    We just bought a Mitsubishi 65" 1080p DLP HDTV and when we connected the xbox 360 we received no video or audio. We also used the cables that came with the xbox 360. Our Wii, dvr,dvd, etc all work fine.
I have a lcd sony full hd latest model ... which is the better cable hd av cable or hdmi av cable or 360vga hd av cable for my x box ///............... im so confused what to choose for a bettre picture on my lcd ... please help me
Posted on Dec 27, 2008
  • 38 Answers
To get the latest video decoder firmware to support all the latest TV's, connect your xbox to xbox live and when you get an update, those update come in an xbox update. If your TV is that new, you NEED to connect to xbox live or get an older TV. Also make sure your television is showing you the correct input that the xbox 360 is connected to. If you aren't on the right channel, you won't get any video or audio.
Posted on Apr 27, 2008
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 58 Answers
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Posted on Jun 11, 2007
SOURCE:
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Xbox 360 elite, no out put,blank screen ?
Make sure your connections are correct. If your using the HD component cable make sure the switch is selected to HD, if you have a HDTV or TV for a regular CRT tv.
HDMI, select the proper input on your tv remote.
Mar 30, 2010 | Microsoft Xbox 360 Console
How do i use a hdmi cable on my xbox360 elite
Purchase an HDMI cable, connect one end to the back of your 360 elite, connect the other to the back of your television. Power up your 360. If there are other issues, please let me know and I will do my best to assist you
Nov 16, 2009 | Microsoft Xbox 360 Elite Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
XBOX 360 Elite HDMI problem
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Microsoft Xbox 360 Console
Hdmi cable connected nothing happens
Are you making sure to change the input settings on your TV/Home Theater System? You may have to instruct the receiving device to use the HDMI input.
Also, are you have to make sure that the settings in the XBOX are set to use the HDMI output instead.
I honestly don't own an X360 so I couldn't tell you for sure. This is a general principle one must keep in mind when using electronics in general, really.
But I did take some time to track down an instructional overview of using an HDMI connection. It's actually on MS's XBOX site. Perhaps this will help you?
Click HERE to see this site.
Also there has been the occasional report of the HDMI cable coming with the XBOX 360 Elite being nonfunctional. You may consider testing with a different HDMI cable.
Remember to make sure you are checking the OUTPUT on the X360...and the INPUTS on your HDTV. Or your Home Theater system...if that's where you're connecting it. Remember that you may need a second HDMI cable to go FROM your home theater system to your HDTV if that is the case.
Let us know what happens!
Cyryl
Dec 07, 2007 | Microsoft Xbox 360 Console
XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Nov 25, 2007 | Microsoft Xbox 360 Console
Xbox 360 Elite connected to Mitsubishi HDTV Model No. WD62528
Hudeez: 1. Did you check your TV Menu Settings ?? 2. Also on the XBOX 360 Menu. Go to the SYSTEM MENU (PURPLE). CONSOLE SETTINGS and select DISPLAY. Then you'll find the HDTV Settings and pick your resolution for TV Set. Done....
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
226 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
