Question about Refrigerators
Hotpoint HTS22GBMARWW refrigerator w top freezer - not cooling
Freezer wasn't cooling - and fan was running for a long time - hours. everything in freezer was thawed.
Then checked it - later and everything was frozen.
Thought - problem solved - kind of.? But then checked a few hours later and all food is thawed again - and for the last day - hasn't kicked back into cooling.
Have misplaced the manual that came with it. Have swept coils in back, unplugged and plugged back in, then we messed with the cooling controls - and now - frantic that nothing seems to be working and we cannot remember the procedure to "reset" if that might be a solution to the problem.
thank you!
    Genius:
  • 1,036 Answers
This seems to be a model with an automatic defrost cycle.
The good news - is that everything major is working.
The bad news - it doesn't know when it needs to defrost or cool.
The reset is simply to turn it off for 10 minutes as there is no memory storage on these.
Hotpoint have a little get-out-phrase that they use sometimes - location.
If the room is too cold - it can sometimes affect the temperature difference between inside and outside the unit enough to make it think it needs to defrost. I think it's 15 degrees C that things start going wrong.
If the room is fine, then it is probably the freezer sensor that is strapped to the cooling coil at the back inside the freezer compartment. This tells the control when it's frozen solid - and needs defrosting. If it is not sending the correct resistance to the control, it can either defrost too much - or not at all.
If you can turn it off, and get to it to check it, check the contacts first, clean them if possible, replace covers and try again. If no change you will need a replacement. Some models you cannot even get to it, so if this is the case, a replacement control board is needed, or the wires from it need terminating together - dependent on model.
Posted on Jan 10, 2009
Hotpoint fridge not working
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
May 27, 2012 | Hotpoint FFS90 Bottom Freezer Refrigerator
Freezer works fine, fridge barely cool. Hotpoint HTS22GB
If you cannot here the fan running in the freezer, you will need to replace the evaporator fan motor. Here is a link to the part you will need.
Aug 02, 2011 | GE Hotpoint Top-Freezer Refrigerator
A loud humming sound is coming from the freezer section. What should I do?
Ice build up hitting the fan???
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 08, 2010 | Hotpoint HTS17BCSR Top Freezer...
Top section of freezer dept; food not frozen
Your freezer fan is not running. Defrost for 12 hours then switch on again. Normally that will be the solution. If it still does not cool correctly after that, call a technician as equiptment will be needed to sourse the fault.
Aug 18, 2010 | Hotpoint Refrigerators
Hotpoint freezer fan noise?
First check that you do not have a bagged item in front of it. I have done this myself - so is easy to do. The plastic bag touches the fan - making a noise.
Next - check freezer is defrosted regularly.
The fan is used to remove the moisture in the freezer when the door is first closed - freezing it to the evaporator coils - to be safely removed later.
Sep 08, 2009 | Refrigerators
Freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
May 29, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
No cooling in refrigerator
air passage from freezer to the lower door maybe blocked with ice build-up
May 06, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Refigerator not cooling and hot to the touch
It sounds a lot like lost charge caused by a leak in your system. If your unit has been moved or improperly cleaned, some part of the pressurized system may be damaged.
Refrigerant (with very small molecules) may leak off over many years but it shouldn't happen in the single digits.
Apr 05, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
18 cu inch refrigerator ge hotpoint
my freezer is set higest and meats frozen ice cream soft the refrigator part is set on #9 but everything is not warm but just a little cool
Jun 16, 2008 | GE GTH18JBR Top Freezer Refrigerator
Refrigerators Logo
797 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
