Question about Honeywell HV-180 18" Commercial Grade Floor / Box Fan
I need a fan motor for my Honeywel HV-180 commercial grade floor fan, where can I find one?
P/N: 001-02054-004, Ref. niumber DM-180 , Year 2004
2 Suggested Answers
SOURCE: I owna honeywell commercial grade
The front wire grating has hooks all around the edge that latch onto the rear grating. You need at least two screwdrivers, blades or thin & stiff shims to pry half the hooks off. Do this by inserting your shims between the front and rear grates, on either side of a hook. Then, lever your shims such that the rear grate warps enough to free a hook and let it pass in front. (Note: this IS difficult; the first hook will not want to clear the rear grate. It helps to have an extra pair of hands, and/or another object to temporarily keep the first hook seperated. It may also be possible to start with three shims and clear two hooks in the beginning). Continue clearing the hooks in a consecutive fashion (they're progressively easier) until half of them are off, at which point the front grate should come off using a little muscle. A couple notes: if available, a plastic shim is preferable over a metal one because it shouldn't damage the nice finish as much (alternatively, wrap your shims in cloth). It is NOT necessary to remove the whole fan cage from the stand to do this. Expect the reverse process to be equivalently challenging. Please wear safety glasses in case your shim breaks or slips. Lastly, good luck if you try to lubricate the shaft. I've tried multiple substances, but day-long blowing continually dries out the lubricant.
Posted on Jul 30, 2008
Hi, we have a Duracraft Commercial Grade High Velocity fan. When we turn it on it just hums, fixable? thanks, Nancy
Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
Sep 01, 2011 | Duracraft DS-1600 Fan
Hello i have a hv-180 18" when i plug it in
Yes. These fans have thermal protection in the motor, as well. The thermal fuse or thermal breaker may be bad.
Mar 09, 2011 | Honeywell HV-180 18" Commercial Grade...
HOW DO YOU CLEAN THE FAN BLADES?
there should be just some sort of snaps, or hooks holding the guard on. I have yet to see a fan that doesn't. but if there is any, take the clips off of the guard, and clean the blades.
Aug 12, 2010 | Honeywell HV-180 18" Commercial Grade...
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
HV-180 fanFan has dust on enclosed blades and on cover. Would like to clean. How?
The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
May 28, 2010 | Honeywell HV-180 Floor / Box Fan
I am looking for a fan control knob for this unit at our hospital
Radio Shack carries many types of control knobs. They may have one with the shaft configuration you need or get one with a set screw that you can tighten onto the shaft.
Aug 25, 2009 | Honeywell HV-180 18" Commercial Grade...
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
I was wondering how to clean a 14F0 fan?
all you have to do get your vacum cleaner or unscrew all screws before opening your fan.
I owna honeywell commercial grade floor fan HV180. How do i clean it? I cnnot seem to get it apart.
Jul 20, 2008 | Honeywell HV-180 Floor / Box Fan
Fan stopped working
It's possibly a lubrication problem. I can't seem to keep mine lubricated, so good luck with yours.
Jun 27, 2008 | Honeywell HV-180 Floor / Box Fan
Honeywell HV-180 18" Commercial Grade Floor / Box Fan Logo
212 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
