Question about Toshiba Satellite A75-S2112 Notebook
Changing memory cards
Can I use a spare memory card from my Toshiba Satellite A75 into the slot of another laptop Toshiba A10-S1001 to upgrade it? Are these laptops compatible?
  • Eber Stevao
    Eber Stevao Jan 13, 2009
    Thank you my friend! I got it all solved. Take good care now.
  • 59 Answers
Easiest way to check would be to physically look. There should be labels on the memory to verify the type. It doesnt have to be the same brand or size just the same type and frequency. Example DDR2 4200 and DDR2 533MHZ are the same.
Posted on Jan 10, 2009
My Toshiba Satellite A10 S1001 won't boot to cd. what should i do?
Try tapping F12 when you first power on your computer. Or there should be prompts at the bottom of the screen with you first power on the computer that tell you what keys to press to enter Setup or One Time Boot Options. If you enter the Setup (BIOS) then be careful of what settings you change, as it could cause problems.
Jul 06, 2010 | Toshiba Satellite A10 S1001 (PSA10U3V1JG9)...
I have a Toshiba Satellite A75-S2112. It is
there is a panel underneath with a small phillips head screw holding it. take battery out first, then flip computer over. Take out screw(place in zip loc bag for later)..ground your hands on metal somewhere, and then release the memory cards, by holding extreme outside edges. make sure NOT to touch gold fingers. Make certain you have compatible memory before you do this.
Nov 29, 2009 | Toshiba Satellite A75-S2112 Notebook
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    Adding memory to a a75-s211
    How much memory did it have before you removed the 256Mb RAM?
    If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
    Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
    Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
    Toshiba A75-S211 memory
    I'm showing a base memory on that unit of 256 so your max upgrade is 1gb to 1.2gb total.
    1GB (1x1GB) Toshiba Notebook 2.5v PC2700 DDR333 SODIMM
    Apr 14, 2009 | Toshiba Satellite A75-S211 Notebook
    Change RAM in Toshiba Satellite A75 notebook
    The Toshiba Satellite A75 came with either 256megs or 512megs of NON-REMOVABLE RAM. You will be able to insert a 256meg, 512meg or 1024meg stick of RAM in the slot. There will only be ONE slot to put the memory into. The only other socket on that computer will be for a wi-fi card but you would not be able to stick memory into that slot. The type of memory you will need is DDR333, PC2700, 200 pin SODIMM, 2.5 volt sync.
    Apr 05, 2009 | Toshiba Satellite A75-S209 Notebook
    Toshiba A75-S211
    You can do either.
    I suggest that if you want to double your memory capacity is to buy another memory module with the same specs and size as the existing one, preferrably from the same manufacturer.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Adding memory to Toshiba A75-S211
    you buy the memory here for a great price or anywhere online instructions are on the page
    it replaces the 512
    http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    I could be wrong, but most laptops have all the peripherals intergraded into the motherboard in order to get such a slim profile all on one board. The sound card, video card, network card, and all are non removable and non replaceable. When it comes time to upgrade, then you'll have to start looking for another laptop. Sometimes though, Toshiba will have driver upgrades on their website for new features and fixes.
    Apr 26, 2008 | HP Pavilion dv6000z Notebook
    Can I upgrade to a Graphics card?
    Only high-end gaming laptops from manufacturers such as Alienware are capable of upgrading their graphics cards.
    This model is not capable of doing so. Sorry.
    Also, do not leave me a poor rating simply for the fact that this is not the answer you wanted to hear, please.
    Thanks.
    Cyryl
    Dec 08, 2007 | Toshiba Satelite A10 Notebook
    Toshiba Satellite A75-S2112 Notebook Logo
    270 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
