Question about Microsoft Xbox 360 Console
Xbox 360 Elite connected to Mitsubishi HDTV Model No. WD62528
I connected the Xbox 360 Elite to a Mitsubishi HDTV using the HDMI cable. No picture, just a blue screen. Tried using the HDAV cable, same output - none. What am I missing? HELP! Thanks for any recommendations.
  • 32 Answers
Hudeez: 1. Did you check your TV Menu Settings ?? 2. Also on the XBOX 360 Menu. Go to the SYSTEM MENU (PURPLE). CONSOLE SETTINGS and select DISPLAY. Then you'll find the HDTV Settings and pick your resolution for TV Set. Done....
Posted on Jul 03, 2007
I was having trouble with my component AV cable. I went to purchase a new cable, HDAV component cable and connected the xbox. I had an image for a short time and now do not. Please help!
your HD settings may be too high, go to "display settings and change them, if your not on an HD tv, change the output to "TV" on the AV cord where it connects to your xbox, if you Are on an HD tv make sure the output is set to "HDTV" on the AV cord where it connects to your xbox, there is a little switch on the side that slides left to right
Jan 16, 2010 | Microsoft Xbox 360 Elite Console
I recently bought an xbox 360 and hooked it up to my HDTV via HDMI cable and everything was working fine. Then I tried to connect to xbox live, prompted to download updates otherwise I canot use the...
Go to system settings then display then change your output to like 1080i or 1080p and see if it works if it doesn't try different outputs because i can't think of them right now but their are two other different outputs adjust your t.v. accordingly and see if that fixes the problem if it doesn't try a different t.v. or take the cords back and get different ones.
Apr 04, 2009 | Microsoft Xbox 360 Elite Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Xbox only sits on tv blue screen
Try usings a componet cable or a standard AV cable if your using HDMI then go to your settings and change it to HDMI output
Feb 16, 2009 | Microsoft Xbox 360 Console
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
XBOX 360 Elite HDMI problem
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Microsoft Xbox 360 Console
Hdmi cable connected nothing happens
Are you making sure to change the input settings on your TV/Home Theater System? You may have to instruct the receiving device to use the HDMI input.
Also, are you have to make sure that the settings in the XBOX are set to use the HDMI output instead.
I honestly don't own an X360 so I couldn't tell you for sure. This is a general principle one must keep in mind when using electronics in general, really.
But I did take some time to track down an instructional overview of using an HDMI connection. It's actually on MS's XBOX site. Perhaps this will help you?
Click HERE to see this site.
Also there has been the occasional report of the HDMI cable coming with the XBOX 360 Elite being nonfunctional. You may consider testing with a different HDMI cable.
Remember to make sure you are checking the OUTPUT on the X360...and the INPUTS on your HDTV. Or your Home Theater system...if that's where you're connecting it. Remember that you may need a second HDMI cable to go FROM your home theater system to your HDTV if that is the case.
Let us know what happens!
Cyryl
Dec 07, 2007 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
188 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
