Question about Canon imageRUNNER C3200 Copier
Canon imageRunner 3200n paper jam in the fixing unit
My irc3200n keeps on saying there is paper jam in the fixing unit when there is no paper there , but what i have noticed is that there cutting marks on the upper roller as if a small screw was stuck between the rollers can this be the problem and what can be the solution to this problem?
Check the paper delivery at fixing unit. the flag sensor sometime block the sensor. so modified a little bit
Posted on Mar 24, 2010
    President:
  • Canon Master
  • 990 Answers
Hello sir;pull out fixing unit check out the paper sensor that located at the paper exit side,let it move freely.
Posted on Jan 10, 2009
Says paper jam but no paper jam
normally you can find paper roll with your fixing film,try check fixing unit and hope it will help you
Sep 24, 2011 | Canon ImageRunner 2025I Black and White...
We have an imagerunner c2620 the fixing unit went bad and we just replaced it. Now it says there is a paper jam in that area and there isnt any paper where indicated
Did you replace worned out unit with new one?
If Yes, check the connectors of sensors and connectors from fixing unit to copier.
Did you remove all protective sheets from new fixing unit? Check that nothing is in paper path way or that sensor flapers arent broken.
Leave an email, and I can send you the service manual.
Sep 17, 2011 | Canon imageRUNNER C2620 Color Copier
Canon image runner 2200 has paper jam. I'm missing the manual to check the paper path
On display should be detaild description where the paper is jamed. In duplex, in fixing, in cass.,...
If there is no paper picked up - change rollers from cass., if the paper is got out or pass fixing unit, check the sensor flapper in fixing unit - if respond is slow apply wd40 on it or replace it.
May 18, 2010 | Canon imageRUNNER 2200
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Consant paper Jam - Canon 1600 photocopier
Try to clean the rubber parts. Probably these are filled with paper dust.
Jul 22, 2009 | Canon ImageRunner 1600 Copier
I wont conect canon irc3200n for my computer
check machin & system IP address is equal ie. mac ip 192.168.1.152 then system IP 192.168.1.* chenge * with 1 to 199
May 08, 2009 | Canon imageRUNNER C3200 Copier
Where is the fuser located in imageRunner 3200n drum
but why do you want to go to service mode.
1º key of adicional functions
2º keys 2 and 8 than again adicional function.
Dec 22, 2008 | Canon imageRUNNER C3200 Copier
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Canon imageRUNNER C3200 Copier Logo
401 people viewed this question
old marine
old marine
