Question about Kenmore 19233 Computerized Sewing Machine
Bobin how do you know if you have the bobin in correct
  • palapa18 Jan 15, 2009
    I don't know how to remove the clear plastic cover on the bobbin to change the thread (rethread)
    New Friend:
  • 186 Answers
The thread should un-spool clockwise when looking down at it.
good luck!
Posted on Jan 30, 2009
The top thread will not pickup bobbin therad it is a pfaff 5.0 machine
The bobin may not be in correctly. When looking at the bobin, with the thread threaded through the bobbin case, make sure that it spins counter clockwise. Also the problem could be caused by the machine not threaded correctly. But it is more likely the bobbin case and bobbin
May 04, 2017 | PfaFF Sewing Machines
In my Janome Memory Craft 3000 my material got pulled into the area where my bobin thread comes from. I pulled it out. Now my needle is dragging but not breaking on the white piece underneath where you...
I would suggest replacing the needle, make sure the needle is correct for the fabric and thread being sewed.
sometimes when the fabric gets caught in the feed dog area, there are different reasons, I'll list some below
fabric is too thin--needs stabilizer
top thread has some off the thread take up lever
bobbin is turned the wrong way in the bobbin case
needle is damaged--replace needle with correct size for fabric being sewed--and insert the needle correctly into the needle holder.
if these suggestions don't help, I also suggest having the machine checked to see if there is some other problem like timing.
May 03, 2014 | Sewing Machines
Hi, i dint know what happen to the bobine it's just stucked. I've taken out the needle or it Will be broken When the press to stitching. Please advise what's wrong with it. Thanks.
The part that holds the bobbin should not turn, It should remain stationary. You can see at the end of the video how it has shifted and the outer moving ring hangs up on it. It is either not seated correctly or something has broke, looks like you may need to take it in for repairs.
Feb 03, 2013 | Sewing Machines
Sewing machine problem
if the bobbin winder spindle will not return to it's original position, then there's a part in the machine that not working correctly, & it needs to be serviced,
Feb 27, 2012 | Husqvarna Sewing Machines
I CANNOT PICK UP THREAD FROM BOBIN TO NEEDLE. I HAVE CORRECT THREAD ON MACHINE AND BOBBIN-BOBIN IS IN CORRECT NEEDLE IS CORRECT. THE MACHINE I HAVE IS THE 3230 ELNA AND it SEEM TO BE SOMETHING WRONG WITH...
* Try to hold the end of the top thread towards to the back of the machine while you turn the hand wheel towards you .* Have the tension on top set to four.
* Check the bobbin tension. It should be set to set to four. This is an equivalent pull with the above tension.
*If this doesn't work the machine will need to be "timed" properly. Your local repairman can help.
Sep 04, 2017 | Elna 3210 Mechanical Sewing Machine
The top thread is looping every 30 or 40 stitches on my Juki DDL 8700. I put in a fresh needle, cleaned thoroughly, fresh throat plate and re-threaded. Any ideas? Thank you!
hi there
please check bobin case spring maybe need t adjust or rplace.
please check if you are wind bobin by correct way not too much titght or not too much loose. thread insaid bobin must be littel soft.
the last reason maybe the tip of stoper for hook id damaged and need to rplace.
best regards
ashraf abozid
aabozid@hotmail.com
Dec 01, 2010 | Juki DDL-8700
Lower thread tension is too loose but no adjustment seems to work
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 28, 2008 | Brother LS-2125 Mechanical Sewing Machine
Thread is clogging up under fabric and is not catching bobin thread
I have the same problem, I fix it by removing both Shuttle hook and Bobbin Case and tested it to see if the shuttle hook rotated freely within bobbin case. I noticed the screw for the tension spring was too high and was rubbing agaist bobbin case. Just tighten screw on spring and and recheck for rubbing.
Sep 06, 2007 | Kenmore 15343
Kenmore 19233 Computerized Sewing Machine Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
