Question about Fargo Pro L ID Thermal Printer
Fargo printer display DRAM MEMORY BAD
My fargo printer does not show anything on the display after changing the memory, and power it on it displayed DRAM MEMORY BAD
  • 526 Answers
The memory module will need to be replaced on that unit, I believe on that unit it is replaceable. I have worked on these before. we are an authorize service center forit.
Posted on Apr 16, 2009
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
Fargo DTC300, prints yellow and magenta, stops at cayn
is a printer thermal head dirty on same position. clean with a clean dry cloth, and special cleaner (see on manual)
Jul 15, 2010 | Fargo DTC-300 Thermal Card Printer
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
My Xerox Phaser 6110MFP got error "Internal Error WER OFF/ON DRAM-FUNC.C 58 R". Cannot get solution from any sites. Can't use printer. Please help, thanks.
Use this feature to test the machine's DRAM. The result appears in the LCD display.
If all memory is working normally, the LCD shows << O K >>
Jul 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
May 12, 2009 | Fargo 4250 Thermal Printer
Ribbon out displayed
Your RFID tag might be bad. You might want to replace RFID board.
Feb 16, 2009 | Fargo Office Equipment & Supplies
At POST I get 2 short beeps
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly
Short continuous beeps: Bad power supply
1 short beep: DRAM flash error
2 short beeps: DRAM ECC check error
3 short beeps: DRAM detect error
5 short beeps: CPU error
6 short beeps: Keyboard error
8 short beeps: Video card error
1 long and 3 short beeps: Bad DRAM
1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
BIOS Beep Codes
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
# of Beeps Error Description
1 Refresh Failure The memory refresh Circuitry is faulty
2 Parity Error Parity error in the Base (1st 64K) of memory
3 64K Base Memory Error Memory error in the base memory (1st 64K)
4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
5 Processor Error CPU error
6 8042 Gate A20 Failure Unable to switch to protected mode
7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
9 ROM checksum error The ROM checksum does not match that of the BIOS
10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error
1 Short Beep Normal POST, System booted OK
2 Short Beeps POST Error - Code on Display
No Beep Power supply or Motherboard error
Continuous Beep Power supply or Motherboard error
Repeating short beeps Power supply or Motherboard error
1 short, 1 long beep System board error
1 long, 2 short beeps Display adapter error (MDA/CGA)
1 long, 3 short beeps Display adapter error (EGA/VGA)
3 long beeps 3270 keyboard card
Phoenix BIOS
The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
Mar 13, 2008 | Konica Minolta Di1610 Copier
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Fargo Pro L ID Thermal Printer Logo
101 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
