Question about Dryers
Dryer shorting out electric supply
Hi
I have fitted a new heater element to my indesit is60v tumble dryer. once the dryer reaches temp it cuts out all of the electric. Is it likely to be the earth connection?
  • langl1 Jan 10, 2009
    THANKS WILL HAVE A LOOK.
    Sergeant:
    Champion:
  • 262 Answers
You have something shorting to ground check the limit switches on the heating element and all wires going to it there is a bare/broken wire some where in this circuit
Posted on Jan 10, 2009
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Indesit Dryers
Indesit IS60V tumble dryer runs but doesn't heat
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Apr 19, 2010 | Indesit WA 115 Front Load Washer
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
Hi, My Indesit is60v tumble dryer has developed a heating (or lack of) fault. I have replaced the heating element & stats. I notice that it only heats when the drum is going in one direction, when it...
yes it will heat in one direction the longer clockwise one... when it does its short reverse tumble it switches off... there is also a duct thermostat that could be causing the premature heat output but also check the vent pipe and hose for blockage plus door filter remove and look down the hole as build up could be hidden...
Dec 18, 2009 | Dryers
How do i replace drive belt on an indesit is60v tumble dryer please
Sep 09, 2009 | Dryers
No heat on Indesit IS60V tumble dryer
The heater and stats are located at the rear of the m/c behind a removable panel.
you need a meter to test them, more likely to be a stat problem, but again you must test them for continuity.
Plz leave feed back for my solution.
Thanks.
Dec 14, 2008 | Indesit WA 115 Front Load Washer
Indesit is60v dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Nov 30, 2007 | Dryers
Dryers Logo
173 people viewed this question
Top Dryers Experts
