Question about Fujitsu LifeBook T4410 Tablet PC (XBUYT4410W7003)
Fujitsu LifeBook T4410 sd card boot
Cant boot from an bootable Ubuntu SD Card (made with Unetboot).
3 Suggested Answers
SOURCE: Fujitsu LifeBook P1120
I have successed upgrade my P1120 to 80GB, pls try make 20 GB on Drive C.
and boot using Window98 boot disket, after install window fo Drive, u can use Fdisk to make Drive C active.
After that, P1120 can boot.
Posted on Oct 19, 2008
  • 9 Answers
SOURCE: Fujitsu Lifebook P1120 Won't Boot To CD\DVD
Fujitsu seems to have secretly added a Hardware black list for Booting USB DVD-rw.CD-rw drives.
I have a Stylistic ST5032D slate.
Your either going to have to buy fujitsu's over priced external drive or buy fujitsu's over priced dock.
Or What I do is Bought WinImage or any other software that allows writing a ISO image to USB flash drive, this should almost always work.
I had to install Windows 7 on my tablet this way.
Choose your poison.
Good Luck.
Posted on May 27, 2010
I cant download any apps says insufficient storage but have an sd card that's empty
You can try moving some of the apps to the SD card. If an app cannot be moved, you will get a warning message. Also, if you have any videos, songs or photos on the tablet move them from the internal storage to the SD card.
Sep 03, 2014 | Nextbook Tablets & eReaders
My fujitsu m532 can't play movies from sd card
My suggestion would be to look at the format of the movie files you're trying to play and search for a movie player app that matches that. If one exists then download, install and open file from SD card with that app. If for example file type is "*. flv" then search for "flv player for android".
My guess is you don't have an app on the tablet that is compatible with the movie file type. Hope this helps.
May 23, 2014 | Fujitsu STYLISTIC M532 Tablet
Im using a tablet and I cant move apps and games to SD card
Hi if you want move apps to sd card go to settings, application and there press on the app which you want move. On the next screen you will see details about the app and a button move to sd card, just press it and the app gonna be moved to sd card. Bear in mind that some of the application can't be moved you will see then grey button.
Apr 01, 2014 | Tablets & eReaders
Camera says insert an sd card when I already have one. will not let me take pictures
maybe the problem is in your SD card, try to used another SD card. and check if it works.
Feb 14, 2014 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Rca tablet will not boot
Here are some common reasons tablets wont boot:
- SD card full or corrupted
Remove SD card (if you have one in your tablet) and try to boot
- Corrupted OS / Application / Data
Try a reset
If your tablet is rooted, you can often boot with the bootloader and wipe the application data.
re-flashing the firmware of the tablet works 99% of the time.
Jan 30, 2014 | Tablets & eReaders
SIM card slot
What exactly are you trying to do with it?
Jul 20, 2013 | Fujitsu LifeBook T4220 Tablet PC
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Jan 27, 2011 | Toshiba Portege M205-S810 Tablet PC
Need a user guide for t4410
Wow this was actually very difficult to find, but I found it for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. Here is the manual / guide:
http://www.fujitsupc.com/www/content/pdf/SupportGuides/T4410_UG_B6FJ-2921-01ENZ0-00%20rB.pdf
Oct 07, 2010 | Fujitsu LifeBook T4410 Tablet PC...
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
Jan 25, 2009 | Toshiba Portege R100 Tablet PC
Fujitsu LifeBook T4410 Tablet PC (XBUYT4410W7003) Logo
1,003 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Michael Vincent Cruz
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
