Question about Roper RTW4300SQ Top Load Washer
How do i put my roper RTW4340SQ0 tub back on its track?
    Top Expert:
  • Roper Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
There is no "track" the tub goes on.
Posted on Nov 28, 2012
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Roper washing machine leaking water
Might be a cracked water valve or dispenser. To get to it you must remove the skin. Click HERE for info on accessing these fine machines.
Posted on Feb 22, 2009
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Does the roper washing machine top loader model# RTW4340SQ0 have a place to put in the liquid softener?
I have the same question but have not find a manual or any other reference that tells me whether this model has a softener dispenser or not. However, I just found this info: http://www.repairclinic.com/PartDetail/Fabric-Softener-Dispenser/8575076A/1195942 which is linked to roper washing machine RTW4340SQ0 parts list. It looks as if the washer doesn't come with the softener dispenser as original equipment but that you can buy this dispenser at repair clinic and just assemble it to the agitator as shown in the video that you will find in the link
Jan 13, 2013 | Roper RTW4300SQ Top Load Washer
I have a Roper RTW4340SQ0 washer that leaks profusely when it fills and throughout the washing cycles. I've checked the water valve and all the hoses associated with it as well as the pump and all the...
This model is direct drive with a front mounted drain pump. The drain pump is THE most common leak location on these type washers! The pumps do NOT generally leak at the hoses, but from the impeller side between the pump and motor. There will be a telltale water mark on motor side of the pump shell.It can easily be fixed by popping the 2 retaining clips, removing the two drain hoses, and pulling off the old plastic pump, replacing it in the reverse order after cleaning the end of the motor shaft. Pumps run about 30 dollars. If you are sure this isn't the culprit, check for signs of leakage between the tub center and transmission, there is a tub gasket there. The tub itself, is not likey to leak, it is one piece with heat welded seams.Go to Youtube and search Whirlpool washing machine repairs, there are a number of instructional videos that show you exactly how to repair these machines and save yourself a lot of money. Incidentally Roper is built by Whirlpool, that's why I said search with that name.
Hope this sheds some light on the problem
kcomp1863
Jan 19, 2011 | Roper RAX4233PQ Top Load Washer
Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Jul 24, 2009 | Washing Machines
My tub come off track, how do I get it back on track
My Spinner is off track in my washing machine. It spins but is not centered which I think is causing water to leak. How can I fix it?
Jul 02, 2009 | Kenmore Washing Machines
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
The washing machine model # RTW4340SQ0 makes a humming noise
Roper is a division of Whirlpool and your machine is still under warranty if only a few months old. You should be able to find a factory authorized service company in your area.
Mar 30, 2009 | Roper RTW4300SQ Top Load Washer
Feb 22, 2009 | Roper RTW4100SQ Top Load Washer
Roper RTW4300SQ Top Load Washer Logo
74 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
