Question about Zanussi ZWF1440 Front Load Washer
Zanussi progress 1400 making funny noise when spinning, also reset itself back to start of program ?
  • 22 Answers
SOURCE: wont epty and spin making noise
check the filter !
Posted on Nov 13, 2008
  • 3741 Answers
SOURCE: Zanussi zwf1421w washing machine makes a
Motor is kicking on and off making that noise....so far for us this has been a motor issue 9.5 times out of 10
CLICK THE LINK DIRECTLY.http://www.youtube.com/watch?v=EqeGv3B-3xw
Posted on May 05, 2009
  • 31 Answers
SOURCE: my zanussi aquacycle 1000 will not drain and pump
the pumps do go duff. you can take the pump of and try it with a 12v supply if the blade goes round free is kk but if it stugles to move you need a new pump you can get them off ebay for a 10er
Posted on Jun 28, 2009
  • 6277 Answers
SOURCE: Zanussi XC6 1400 does not drain properly. Need to
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 21, 2011
FitzOriginal
  • 842 Answers
SOURCE: Zanussi 1400 Front Loader: Machine
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Posted on Aug 30, 2011
E60 fault, zanussi 1400 progress
Call someone to fix the problem
Jan 06, 2015 | Zanussi Washing Machines
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
Washing machine error
HOLD START AND SKIP TOGETHER AND TELL ME WHAT IT SAYS. Also give model and serial number.
Apr 25, 2013 | Washing Machines
Doesn't want to go onto spin cycle just makes funny noises
Possible that there is slippage when the program comes to the spin mode. Please check the drive and see if the belt is slipping or the drive is jammed. If not check the motor drive.
Jan 21, 2013 | Beko Washing Machines
It has now started to make a buzzing noise while using. It works ok through the programs.As if nothing wrong. Could it be the program knob on the front of the machine. It is a Zanussi Jeysystem Excel 1200...
the noise you are hearing from the machine is the recirculating pump, the machine will work perfectly, but noisy. replacing this pump will solve the problem. does the noise stop when it is spinning?
Feb 03, 2010 | Zanussi Washing Machines
My zanussi jetsystem washer/dryer 1400 7kg load machine is not draining or spinning. It is unlocking so I can (at the moment anyway) get the load out, but the clothes have not drained or spun, therefore...
your machine require new set of carbon brushes, and it also may need the pump impeler checked to make sure there is nothing stuck in it such as hair pin safety pin or a wire from the under wired bra.....
Dec 04, 2009 | Zanussi ZWF1440 Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi aquacycle 1400 fle 1416w started to make an electric arking noise when spinning now. Now it has stopped spinning. Will the motor be dead or will it just be the carbon bushes that need replacing....
Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
Regards Faggly
Mar 21, 2008 | Washing Machines
Zanussi ZWF1440 Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
