Question about HP LaserJet 1020 Printer
Must hit enter for each of multiple copies
When I tell it to print 10 copies, it makes me hit enter 10 times. Does anyone have any idea why?
  • 62 Answers
Re-install the printer driver, if that doesn't help, then u need to have the printer looked at
Posted on Jun 10, 2007
How do I make multiple copie?
while you giving print command enter number of copies as much u want.
Aug 12, 2014 | Canon PIXMA Office Equipment & Supplies
MY PRINTER WILL NONLY LET ME PRINT ONE COPY AT A TIME. WHY? IF i HAVE TO PAY FOR THIS INFORMATION, ERASE QUESTION
when you hit print there is windows that will pop up, there you can change the number of copies to print at a time. if you don't change the value from 1 to another number then you can only print one copy at a time. once you are done make sure to change the value set by you to 1 to avoid printing multiples unneeded copies in the future
Mar 05, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Copying contacts from Phone to Sim Card
1 take you to the main menu.
8 gets you to your contacts.
Very top left button with three dots gets you to options.
Then you have to hit the down button 12 times, to get to 'Copy to sim'.
Then hit 2, to select multiple.
Then hit the middle button to select all.
Then hit the very top left button again to copy.
And it will ask you to continue, and hit the very top left button one more time.
Then wait until it has copied them all.
But since you have no screen, you probably won't know when that is, unless it makes the noise it makes when it is done with something. Or just wait a few minutes until you think it is done copying.
Hope this helped.
Mar 31, 2009 | Samsung SGH-A707 Cellular Phone
Trying to print multiple copies and only one copy prints
Hi, my name is Juanita and I will try to help you with your problem.
What kind of printer do you have? And when you say you can't print multiple copies, is it the problem with setting the number of copies in the print dialogue box, or is it the problem for printer settings?
For this problem, I contacted the Inti Prima Karya. It is a cheap printing solution for all your printing needs. It would be much cheaper to use their offset printing solution.
Nov 05, 2017 | HP DeskJet 6122 InkJet Printer
Hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
Nov 20, 2008 | HP LaserJet 1320 Printer
Can't print multiple copies
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
Aug 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Question: Samsung CLP-600N, Vista
Possibly two problems here.
1) Printer on before PC to get a print - an IP address problem ??
Is the IP adress of the printer a STATIC address (usually works better and more reliably), or is obtaining its address from a DHCP server (typically a router, wireless router etc)
Doing an Information print (MENU, ENTER, ENTER) should tell you how the printer is set.
2) Unable to get multple copies.
Possibly a driver problem - get the first sorted out then see if it still does it.
Jan 08, 2008 | Samsung CLP-600N Laser Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
HP LaserJet 1020 Printer Logo
Clive
Clive
