Question about Dryers
Whirpool dryer. Heating element comes on when timer is set and dryer has not started. To keep the dryer from overheating the timer has to be turned off. Sometimes the clothes coming out of the dyer are hotter than normal. The 196 Degree thermal switch keeps blowing.
  • 640 Answers
Defective timer
Posted on Jan 10, 2009
if the element is on all the time it's grounding out,one of the coils are touching the metal case that the element is in,you have to replace the element part WP279838 you can check it with a meter,pull off at least one of the wires going to element,set the meter to 20k touch one lead to one side of the element and the other side to the metal case if you get any other reading other than 1 it's grounded and the element has to be replaced,
Dec 01, 2017 | Dryers
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
I have a Avanti dryer and after its on a few minutes it also cuts off. Can you tell me why or what to do to fix this problem?
see this causes and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub.Replace the Heating Elements
Oct 17, 2012 | Avanti D110 Electric Portable Dryer
Hello my 70 series kenemore is not getting warm and the timer is not completing the cycle to turn the dryer off it just keeps running for hours
I would need a model number to better narrow the problem down for you.
If this is a gas dryer
Remove the lower panel. With the lower toe panel removed, start the dryer & watch the igniter. If the igniter glows & cuts off without lighting the gas this would usually indicate the gas valve coils are weak & will need to be replaced. For this type of repair be sure to disconnect the electrical power & turn off the gas to the dryer. If the timer is set in the auto dry cycle, it will not advance if the dryer is not heating. Once you repair the dryer, the timer should start advancing. It is possible that your old timer is good. If you need further assistance please resubmit your question.
If this is a electric dryer
The timer not advancing from 50 minutes in time dryer & the unit not heating are not related unless 1 leg of the 240 volt supply is lost. Diagnosing a problem like this will require using a volt/ohm meter. With the timer set to time dry you should be getting 240volts to the timer motor & 240volts to the heating element. In the wiring diagram provided L1 comes from the timer on R & goes through the thermal cutoff, oper thermostat & the hi-limit to provide 120volts to 1 leg of the heating element. The L2 leg goes through the motor switch to the other side of the heating element. This is how the element gets 240volts. The timer motor gets its voltage on BK from L1 & OR from L2; this is what advances the timer.
Jan 12, 2011 | Kenmore 700 7973 Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Whirpool Dryer Heating and timer issue
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
Keeps heating on cooldown
needs new timer switch
the timer swithc contains 2 switches one for the motor and one for the heating element, the element switch has fused closed. not reliably repairable,
even if open the timer, break apart the contacts, file them smooth, reassemble, will still lock up again
replacement is less than a new dryer
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
91 people viewed this question
Top Dryers Experts
