Question about Samsung RS275AC Refrigerator
Moisture under vegetable tray
Moisture in refrigerated side
2 Suggested Answers
  • 57 Answers
SOURCE: Freeing food in refrigerator, even vegetables in vegetable tray
You have 2 dials in the refrigerator. One is the thermostat setting the cold temp in the freezer, the other is a damper that allows cold air from the freezer to the refrigerator. Set the thermostat to the middle then try closing down the damper, most say colder or warmer refrigerator. If the damper is closed and your refrigerator is still freezing, then I would guess that the thermostat is bad. A thermostat runs about 40 to 60 dollars wholesale. Retale should be about double.
Posted on Oct 20, 2008
Vegetable compart freezes the vegetables
You probably have your compartment set to meat and not produce. Adjust the setting on the tray, or get the food further away from the air return ducts.
Jan 23, 2012 | Kenmore Side by Side Refrigerator
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
I HAVE A 26 CU FT SAMSUNG REFRIGERATOR. WATER IS POOLING UNDER THE VEGETABLE DRAWERS. I WIPE IT OUT DAILY TO AVOID IT OVERFLOWING TO THE DRAINAGE TRAY IN THE VERY BOTTOM OF THE UNIT. THIS UNIT HAS A LOWER...
I wouldn't be wiping it up. I would let it go into the drainage pan. The design of refrigerators is that the drainage pan is placed by the condenser coils so that the evaporation of the water helps cool down the condenser grill, which increases the efficiency of the unit.
During this time of the year, your furnance is not taking the moisture out of the air so increased moisture in your refrigerator is normal because the air is more humid.
Jun 09, 2011 | Refrigerators
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Water in the vegetable tray
depending alot on your model
this is usually 1 of two things
1 moisture that has condensed in side the fridge or freezer, suggesting that you may a door seal leak
or overflow from a defrost problem
checks: 1 inspect your deasl seal and that all of them are free of obstrcuttion and actually seal the door
2. look at the back wall of your freezer is their
an odd amount of frost
Oct 11, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
The inside of my refrigerator is moist with droplets of water on the inside and water under the vegetable tray.It is a side by side.
drain is stopped up It is in the top behind the panel. there will be some ice there Use a hair dryer. you can then see the drain. should be in middle at back. the best way to unstop it is with air. Hope this helped
Sep 22, 2009 | Refrigerators
Water in bottom of refrigerator under vegetable bins.
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jun 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Water accumulation under vegetable drawer model KTRS22M
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Jun 17, 2008 | Refrigerators
Samsung RS275AC Refrigerator Logo
18 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
