Question about Whirlpool RBS245PDS Electric Single Oven
How do u reset the circuit breaker on the unit?
    New Friend:
The circuit breaker works
Posted on Jun 22, 2013
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
Reset frigidaire oven
Hello christimcwil - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately twenty minutes and restart unit. Set up the time and unit should resume to normal operations.
Jan 27, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Where is the reset button
All the breakers on an electric OV300 would be accessible from the small access panel on the front lower right side of the oven, there should be a sticker on the door that says something along the lines of "circuit breaker here." If those breakers are all in the up position than it is most likely the breakers in your circuit panel.
May 04, 2012 | Baxter OV300E Stainless Steel Electric...
We had a power cut and now we cannot reset the clock or use the oven HELP!
Does anything electrical work on this unit ? do the numbers "light up" for the clock ? if not I would check your circuit breaker box to see if the breaker is tripped. The breaker will be in the middle position instead of being in the on position. If its tripped, flip it to the off position then to on. Check first then let me know.
Nov 29, 2011 | Ovens
We had lighting come in and now our GE electric oven doesn't work. The range top still works but the oven display does not. Any idea's?
Look for a reset or fuse on the unit. If lightening hit, the surge could have wiped it out, as you already know. But hopefully GE put a fuse or breaker in the unit. You just have to find it, if it exists.
According to GE, a diagram is located in behind the control panel. If you can safely remove it (CIRCUIT BREAKER OFF) you may find the protection devices that GE has in place. You may also
find the fuse or breaker hiding in there too! Good luck.
NEVER ACCESS AN APPLIANCE WITHOUT FIRST TURNING OFF THE CIRCUIT BREAKER
OR UNPLUGGING THE UNIT. BE SAFE.
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
I have a F & P Aeron Qantum built-in Oven about 7 years old. It has hardly been used. The top and bottom grills do not come on. The light and air blower does come on. Any ideas?
I am assuming you have an electric unit.......Most likely it is a 220V and is actually 2 110V circuits....there are 2 fuses or circuit breakers that power your unit...replace the fuse or reset the breaker ... what ever applies to you....if the breaker trips or fuse blows again you will need a quilified tech. to assist you further. Please reply.
Feb 19, 2011 | Fisher and Paykel Ovens
Where are my fuses located?
From http://home.howstuffworks.com/how-to-repair-an-oven3.htm Servicing Fuses If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. Electric Oven Troubleshooting Guide There are a myriad of problems that can cause your electric range or oven to malfunction. Click here for instructions on how to deal with specific issues. If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused. If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
Jun 10, 2009 | Ovens
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Oven shut down
hi If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
thank u........
Sep 12, 2008 | Ovens
Whirlpool RBS245PDS Electric Single Oven Logo
81 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
