Question about Sony VAIO GRZ630 Notebook
How do I install more ram in a pcg-grz630 sony laptop
Where is the ram located? Do I access from the back of the laptop?
  • 1,913 Answers
Ya check in back side ram is sitted there.
if u have 1 free slot for ram then u can incrase ram.
Posted on Jan 10, 2009
Can i install 64 bits of window 7 on my Sony VaioPCG-7D2L
Technically Yes, you can.
However, your laptop is quite old now, and may not be suited for 64-bit Windows. You can install and run Windows x64, but it may be slow and unstable.
Why do you need 64-bit?
If you don't plan on running a 64-bit-only application or you have more than 4GB of RAM, chances are you wouldn't need a 64-bit windows installation.
Feb 01, 2014 | Sony Vaio PCG-7D2L PCG-7A2L PCG
Do not know how to enable the wireless switch Vaio model PCG 61A14L aptop. It was working wireless but not any more.
Apparently there is a physical hardware switch at the bottom front of the laptop. This could be switched to off it is for airplane mode. If this doesn't fix problem pull out the battery and remove power cord and change switch and power up laptop again.
Jan 26, 2014 | Sony VAIO GRZ630 Notebook
How to install ram in my Sony Vio PCG-5B1M Laptop
The RAM module/s is located on the bottom of the laptop behind a small panel. Remove this panel will uncover the RAM slots.
To install more RAM try to use RAM from the same manufacturer and RAM speed.
Apr 07, 2013 | Sony VAIO VGN-B3VP Notebook
I was handed up pcg 3g7p and I want to upgrade the RAM to 8Gig from 4. Any advice? I also need to replace the fan so might take it in but would rather do the job than pay for that too?
I don't see a "3g7p" of any sort on Sony's site assuming it is an Sony Vaio PCG laptop of some sort. It would be good to check out the specifications of the laptop on the manufacturer's web site to see if the motherboard will support 8 GB of RAM.
If it does, it will have 2 expansion slots, so you will need to buy two 4GB DIMMS to install. Typically you can access the RAM slots by remove a single panel from the bottom of the laptop.
As far as the fan, you'll need to completely open it up. If you can list the make and full model, we can find a guide to demonstrate how to open it up step by step so you can remove the old fan, install the new one and re-assemble the whole laptop.
Dec 16, 2012 | Computers & Internet
How can i speed up my Sony PCG-GR214EP laptop it is really slow ?
Remove all programs that you have installed and no longer use, next upgrade the RAM memory modules to as large as the expansion slots permit.
Feb 13, 2012 | Sony Vaio PCG GR214EP Laptop Universal AC...
I have a Sony Vaio PCG-K25 laptop and am trying to upgrade to a gig of memory. Is it possible to do this? I put 2 512 memory chips in the slots but it only sees 448. Using Kingston Technology 512 mb...
This laptop has its own graphics card that doesn't rely on system memory for the graphics.
There should be no reason why its not detecting all 1GB of ram that you have installed.
Open the ram cover and make sure that you have clipped the ram into place properly.
Jul 01, 2010 | Sony VAIO PCG-K25 Notebook
Hi i need instructions on how to install a memory card in an old sony vaio pcg-f190 are ther any downloadable ? thanks
Hi astraspirit2. The Sony Vaio PCG-F190 uses 66MHz type memory and usually ships from Sony with 32/64MB of RAM. The Vaio PCG-F190 supports up to 192MB of RAM.
Most laptops have the memory compartment (at least the expansion socket or both) at the bottom. Flip the computer and you will see a little compartment (sometimes it even has a little chip logo). You will need a phillips #0 or #1 screwdriver. It's really simple, you insert the memory in the socket at an angle and then push it towards the laptop. I hope this helps.
May 14, 2010 | Sony Computers & Internet
Sony pcg-tr3a laptop beep continue &notbooting
Ur ram is not working u need to change ram.this beep is becouse ur ram is nor wroking.
Plz dont forget to rate thnx
Sep 09, 2009 | Sony PCG-TR3A Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Sony VAIO GRZ630 Notebook Logo
131 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
