Have panasonic tv TH-l39EM5a connected DAC to RCA output to simply add 2 speakers. can't get a decent sound level or adjust volume, is this expected?
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Posted on Nov 11, 2007
Benimur
  • 6966 Answers
SOURCE: creating a surround sound system
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 16, 2008
  • 19 Answers
SOURCE: Audio Recording
There are many streaming audio recorder. But I prefer Wondershare Streaming Audio Recorder,It can download streaming video offline,you can download aol radio,myspace music and so on.
http://www.download-streaming-video.com/streaming-audio-recoder/#137
You can have a try.
Posted on Mar 31, 2009
SOURCE: Volume Problems: Panasonic TH-42PZ700U
please could you send me tips of what the problem of my plasma keeping stuck pixiel panorama LCD Tv model 42LC68T
yungdub
  • 93 Answers
SOURCE: Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Posted on Jun 14, 2009
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Panasonic Model TH-50PH10UKA. Hooked up to surround sound and works well. When I connect to a second input do not get any sound, how do I turn TV speakers on or Off.
Found in menu setting of tv.are you using RCA or hdmi or optical output as these need to be set in mode setting on soundboard and tv menu settings.
Jan 03, 2015 | Panasonic Televison & Video
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Jun 30, 2011 | RCA Audio Players & Recorders
We have an Magnavox 26mf337B and we have no sound
A TV without sound is awful. So let's take some steps to see if we can get it up and running.
1) Check your input cables - if you're trying to watch something through another device (cable box/satellite box/dvd player ETC) make sure that the cables coming from it are inserted correctly into the TV. If the device has it's own seperate sound output (VOL controls) be sure they are turned at least midway UP.
2) Check the settings on your TV - Sometimes TV's have a setting where you can select audio output (speakers, 2.1 5.1, stereo, etc etc) Make sure you have it set to output sound to it's own speakers and adjust the volume to an audible level.
3) Check the audio OUTput on the TV itself - Connect the white and red (or in some cases black and red) RCA jacks to the audio input on a stereo receiver. See if sound comes out. If this is the case, you have either selected the wrong output on your TV's settings, or your Tv's speakers are dead.
Hope this helps you solve your issue!
May 11, 2011 | Astar Magnavox 26MF337B 26 in. HDTV LCD TV
Hi I have just got a JBL SCS200.5 BK, 5.1 loud speaker system. I am having the following problem with connecting the loudspeaker system. 1. I have a satellite TV reciever with a single Left, Right &...
I guess you didn't get the owner's manual, huh?
http://www.jbl.com/HI-IN/Products/Pages/ProductDetails.aspx?PID=SCS200.5BK/230
Where are the amplifiers in this scenario?
Page 8: The sub needs a subwoofer Line Level pre-out from an AV Receiver or multichannel processor. Though not elaborated on in the manual, the L and R Line Level RCA connections are probably for use if you lack a Sub Out feed. Running L and R from your receiver would allow the sub to derive a Sub Channel.
The rest of the speakers would connect to the AVR's speaker outputs.
Pasge 9: Alternate method if your eelctronics lacks a volume-controlled sub pre-out. This method routes only the front speaker level power to the sub so it can extract something resembling an LFE channel, then it routes speaker wire out to the front speakers, not as an audio power source but simply as a pathway.
You still need amplifier channels for all but the sub.
Apr 25, 2011 | Audio Players & Recorders
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Oct 30, 2007 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
