While in another part of the house I heard a crackling noise. The lights started to flicker. As I started searching for the noise, I came into the great room to find blue flames coming out of one of the sockets on the ceiling fan. I turned the light off. For something to draw enough current to cause a flame, should the breaker not have tripped? It did not. The circuit breaker is a 20 amp breaker. It feeds two celing fans in a large great room both with light kits. Light kits have 4 40W bulbs each.
Not always. It sounds like your wiring burned up. If there is not a lot of load on the circuit it's possible for the wire to catch on fire and not trip the breaker. Breakers will only trip when the amperage exceeds their rating. If the wire is still intact and not shorting to the case it will not trip the breaker. I had the same thing happen to us on a job friday.
I would turn the breaker off, test and ensure the power is off, then remove the light that had flames shoot out of it. Chances are there is a wire in there that is blackened. If there is you can look into buying a new light kit. If you feel you can do it safely and you can get enough wire on each side of the burned part, you can try **** splicing a new piece of wire in. If the inside is all burned up the safest thing would be to replace the whole light kit or fan.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE WPXH214A Front Load Washer
I have a w10117769a and the I have clothes in the washer that completed it's cycle of cleaning and...
(More)
I have a w10117769a and the I have clothes in the washer that completed it's cycle of cleaning and the door will not open. The manual said to press the stop button to open which I tried and the add garment light came on. I tried starting and stopping the machine with no luck. The machine is stuck and will not unlock the door
