Question about Ariens 42" Riding Lawn Mower Blade 03987000
Arien ride on mower deck belt keeps breaking - Ariens 42" Riding Lawn Mower Blade 03987000
  • 81 Answers
SOURCE: Ariens ride on mower
The most likely cause of the mower belt coming off is a bearing in the quill assembly which are the upright units that have the pulley on top and the mower blade on the bottom, what usually happens is a bearing statrts to go bad, which allows the pulley to startmoving out of alignment with the other pulleys which causes the belt to ride up on a flange and come off. Usually I reccommend that when you replace one bearing or complete quill assembly you replace all bearings, or quill assemblies this way everything is in like new condition and the problem should be solved. Hope This Helps Don
Posted on Nov 10, 2009
Testimonial: "Thank you for your imput will fix my problem. Iam also looking for an Ariens rear mount 1028 model number 927023 serial number 004145 workshop manual "
panilling9
  • 284 Answers
SOURCE: Cleaning
http://themojack.com/
Posted on Jun 29, 2010
SOURCE: need owners manual
http://www.ariens.com/corporate/pages/customerservice.aspx
Posted on Jul 18, 2010
  • 203 Answers
SOURCE: I need an owners manual for an Ariens Sierra 1640
Go you to this page and enter your model and serial number:
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.8213132047263072&Site=ARIENSS
Good Luck
Posted on Dec 05, 2010
SOURCE: Cant find the PTO deck belt for a Ariens Sport
I own this model as well. The manufacturer issued a "cutting improvement kit" for this model number. The belt number has changed as well. The number you now need is # 07242200
I am in the process of ordering one for mine right now. Good luck!
Posted on Apr 17, 2012
Snapper NXT236 keeps twisting and breaking mower deck belts
check for failing cutter shaft bearings , misalignment of pulleys , incorrect belt tension, wrong section belts in use
breaking belts is an indication of the belt going around a pulley and flexing against the belt fabric structure ( bending backwards as opposed to running properly in the groove) which indicates that the tension pulley is on the wrong position on the belt
Jul 14, 2016 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Zoom 42 mower deck belt routing diagram
Andy, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Zoom 42 mower deck belt routing diagram Google Search
http://apache.ariens.com/manuals/00173200.pdf
How to Replace the PTO belt on an Ariens Zoom Zero Turn
Ariens Zoom 42 Owners Manual
May 07, 2016 | Garden
How does the belt go on the mower deck of an ariens riding mower model 936083
Not to scale or every detail but should give you a good idea how it goes.
May 09, 2015 | Ariens Garden
How to replace deck belt on ariens model 960160027 lawn vtractor
Please go to the Ariens website and download a manual for your mower.
Jun 29, 2014 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Cant find the PTO deck belt for a Ariens Sport Zoom Model 915031-1232. Ita a zero turn mower. The manual calls for belt # 07242700 cant find it anywhere! Help.....
Apr 14, 2010 | Ariens 34 In. Zoom Series Riding Mower
Not sure, but i think the electronic clutch is not engaging when i push the control levers forward or backwards. the engine and the mower deck both run, but the mower will not move
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
Nov 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Can someone please help lookingh for belt routing for the mower deck for a ariens riding mover yt12g model and the belt to the mower deck how it routes on tension pulley thankyou john
Hey John..my name is Keith..and you can go to an online lawn mower parts site..and they will have a pic of the deck and they way the belt is routed...one of the sites is www.outdoordistributers.com ...i hope this will help
Jul 08, 2009 | Garden
Ariens sierra 1440G belt configuration
Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
If this doesn’t work for you, please write back. Thanks,
Nov 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Ariens 42" Riding Lawn Mower Blade  03987000 Logo
77 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
