Question about Refrigerators
My WTE5200SB-R fridge part is freezing our food what do we do
We were told by the company to set the fridge at 3degrees cause we had it on 7degrees she said 7 was to cold sowe put it back to 3 now we have a build up of condensation
SOURCE: My fridge is too cold
I wrote under "guest" earlier on Aug 5th. I jave since discovered that the problem is a manufacturer problem. Apparently Liebherr had problems with their sensors, which they have since corrected, but they were put in all the earlier fridge/biofresh. I contacted the Liebherr agent in Melbourne Australia where mine came from (Andi-Co), and they have sent someone out to replace the sensor free of charge (mine has been out of warranty since March 2008). The sensor tells the compressor when to shut off, and when faulty does not do this so the compressor keeps running and freezes everything. I did have to make a bit of a fuss though and write them a letter before they came out. I printed out this page as evidence that it was clearly a manufacturing problem, which they have now confirmed. So I suggest you ask your supplier to fix the problem free of charge. Good Luck!
Posted on Aug 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
SOURCE: ice build up
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
Posted on Mar 23, 2009
erpaalai
  • 999 Answers
SOURCE: my rv fridge will build up ice and freeze food too cold
The thermister for the temp control is a likely culprit. Eric
Posted on Jul 07, 2009
SOURCE: The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
my ice depenser is only making a couple of ice cubes the others are staying iin the ice cube tray
Posted on Dec 23, 2009
My whirlpool fridge is freezing the food in it. What can cause that and how do you fix it?
set at minor temperature,set the thermostat dial at warm temperature.maybe its a little bit empty of food and at full coldest settings
Jul 15, 2014 | Refrigerators
My whirlpool fridge is freezing the food in the fridge. What is causing that?
adjust the temperature settings.change from coldest to colder
Electrolux Side by Side Fridge-Freezer ESE6108WA - freezes food in the fridge
hi its sound thermostat problem not click off when the temperature reach to the set point ,need to replace it.
May 14, 2012 | Electrolux Refrigerators
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge freezing food. Thick wall of ice at back of fridge. Turned down to lowest setting and still freezing.
heatman101
Jan 27, 2011 | Hoover Refrigerators
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
heatman101
Jan 22, 2011 | Refrigerators
The fridge part of my fridge freezer keeps freezing my food. Doesn't matter which setting i put it on.It's suppose to be frost free. Can it be fixed?
heatman101
Jan 16, 2011 | Refrigerators
The fridge section of the appliance is not automatically defrosting the fridge is on the lowest setting but still manages to freeze food and drinks solid
heatman101
Jan 14, 2011 | Refrigerators
I have a blood bank refrigerator with temperature fluctuating from 3degrees to 7degrees and back. This is continious. is it ok.
5 degrees fluctuation is normal, anything over that, then I would suggest testing thermometer and thermostat.
Aug 26, 2009 | Refrigerators
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
