Question about HEWLETT-PACKARD 5188-7535 Motherboard
Don't know where to put the paper
  • 3,799 Answers
What paper are you on about? motherboards don't use paper.
Posted on Nov 28, 2012
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
Says I have a paper jam but don't
Remove fuser assembly mounted on the top, check paper input & out put sensors clean or blow air on it to clean the dust, if found any sensor flag dis located, locate it properly, if found damaged replace fuser unit..
Feb 01, 2012 | HP Color LaserJet 3500 Printer
All telephony functions, including emergeny call are disable due toa communicatio eror
Basically the solution is to claim the warranty and Nokia replaces a new one for you, what if you are out of warranty, just someone like me? Nokia has no answer for that, thank you Nokia ;)
I was thinking "Sim card icon and communication error", maybe it is sim card slot issue? I don't know, but here's what I try -
0. Switch off N9001. Open up N900 case at the back(battery part)2. Take out battery3. Take out sim card from the slot, clean it4. Put the sim card back to the slot5. Tighten the slot6. Take the toilet paper, yes I say toilet paper because it was on my desk when I was trying to fix this7. Try to tear the toilet paper and make it thicker by layering them8. Make the toilet paper slightly same size(square) as the sim card slot9. Put the toilet paper on top of the sim card slot and push in a bit10. Put back your battery and press it little hard, the toilet paper will be underneath11. Close the case12. Switch on your phone
The phone works automagically, don't ask me why, it's really high tech fix if you ever encounter this issue.
Jan 03, 2012 | Nokia N900 Smartphone
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
Hp officejet 8500 premier printer has paper jam alarm,also I don't see paper being picked up from input tray at all
Hi........................
Please click here for solution :-
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP 8500 Premier All-In-One InkJet Printer
Can I put ground coffee directly into the brewer basket to make a cup of coffee? I don't have a coffee pod
Nope, don't put the ground coffee directly into it. Instead try using a Napkin or Paper towel.
A piece of cloth may also be used, but the paper towel is preferable.
Hope it works out!
May 31, 2011 | Vacuums
I m unable to download the proper printer driver for windows xp 32 bit i don't know even how to use this printer where to put paper, & how to change cartridge, what model of cartridge etc
Please check the content of your printer. You should have there the manual , cables, and CD driver. If you don't have, please get down loaded your printer driver at manufacturer website. Check the model and type then search download bar.
May 06, 2011 | Office Equipment & Supplies
Where is the oil filter for a 2005 chevy cavalier located
ECOTec 2.4 Liter engine (and all ECOTec engine blocks in 4 cylinder sizes) have a cartridge type oil filter housing on the front of the block, driver's side of the vehicle.
The cap must be removed with a wrench, and the filter pulled out, then the new one put in. Now is usually a good time to replace the O-ring on the cap.
Dec 13, 2009 | 2005 Chevrolet Cavalier
HEWLETT-PACKARD 5188-7535 Motherboard Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
