Question about Belkin N Wireless Modem-Router F5D8633au4A
Connection keeps intermittently dropping.
This problem has just started. My broadband provider's status reports no connection problems. I can be online for 2 minutes, longer or shorter, and then get cut off. I press for repair and it repairs for a time, and so on. My wireless modem router is the Belkin F5D7633-4. I think the sync light keeps flashing. I'm not sure which one it is as I can't find the manual. Thanks.
  • Anonymous Jan 12, 2009
    I also am having intermitant dicconect isues I have the Belkin n F5D8236-4 router but it only hapens when on an on line MMO Game. I have by passed the router and no issues?
  • 258 Answers
Connect with an ethernet cable and find out the IP Address,
subnet mask, gateway, and dns,
by double clicking on Local Area Connection, click support, click details.
Enter these values for the wireless area connection
To set the values do the following:-
start -- > control panel --> network connections
right click on wireless area connection select properties
click on TCP/IP and press properties
Set to use the following ip address
enter the values from wired connection
ignore any duplicate warning messages
Thiswill resolve the issue, I have used it many times.
Posted on Jan 14, 2009
My modem keeps dropping connection. I have called my ISP and they say everything is running just fine. It happens when i am playing counter strike source and i start lagging badly and all of the sudden my...
Intermittent connection issues are very difficult for internet service providers to trouble shoot. The first step in trouble shooing any Intermittent connection problem is to look at the chain of equipment involved in flow of data from the internet service provider to the end user. In most homes the packets enter from the main line to the modem, than from the modem to the router, and finally from the router to you computer. So that means that the issue can be caused from the following equipment: main cable line, splitter, modem, router, or the Ethernet / wireless card of the PC. The first step in trouble shooting this problem is to wait for the internet to drop off. As soon at this happens go to your modem. If the top 4 lights are not solid green then the the modem is losing it's connection to the internet. This can be cause by some thing as simple as a bad splitter in the home or some thing as complicated at an issue at the pole. If the modem drops the connection I would recommend contacting the internet service provider and demand a service call to swap the modem and check the pole. Now if when the connection drops the modem still has access than the issue is most likely with the router or PC. If more than one computer loses it's internet access than you can rule out the computer as the issue. At this point I would have to recommend bypassing your router for about 48 hours. If the issue does not return than you know the router was the source of the problem.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Router keeps dropping connection
the problem might be with your dsl line. Check to see if it happens with all phones, sky and non broadband equipment removed from your phone sockets. if it still drops contact your isp.
Apr 09, 2010 | Belkin F5D8236-4 Router
Hi, We have SKY Broadband connection at home and we use lapops with wireless connection in different parts of the house, the connection is very intermittent, keep loosing connection every few minutes. Can...
Hello.
If you have a router, check the physical connections to the router and reset the router. If still a problem, the router could be faulty.
Contact Sky Broadband for them to check their connection.
Hope this helps.
Feb 24, 2010 | Computers & Internet
WGR614V9 virgin router drops connection
I should first thank you for the clear details you have given about your connection .I will try best to help you.The firmware version can be older so check the firmware version and upgrade it. Try to open the netgear smart wizard page in your wired computer by going to www.routerlogin.com or 192.168.1.1.The USERNAME:ADMIN and PASSWORD:PASSWORD(default).We can troubleshoot this only if this page is opened.In the netgear page at left side blue screen under maintenance->router status check the firmare version if its older version then click on router upgrade and check for the new version from internet(click on check tab) and upgrade the firmware.Hope this solves your problem if not try with different laptop wirelessly connect if you are able to connect then its the computer problem contact your computer vendor.Rate me if i have helped you that will motivate me.Thank you.Have a good day.
Sep 24, 2009 | NetGear WGT624 Wireless Router
My computer internet connections keeps droping
Hi
make sure that all the connections are in proper state ,goto the network connections and check the status,
also check the ip address by going to start->run-->cmd
type ipconfig
and it should give you the ip address
and the default gateway.
in case if you want a technician to help you with this you maqy get in touch with one of the techbuddies,they provide free tech support for such internet issues,you may get in touch with them at http://techbuddies-robin.blogspot.com/
Jun 17, 2009 | Computers & Internet
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
Trying to install Linksys wrt54gx2 srx200 on my vista computer
who is your broadband provider? Is this cable or DSL connection? Setting up the router is done via http://192.168.1.1. Leave username blank, password is admin. If you have Cable ISP, then make sure you have "Automatic Configuration-DHCP" selected and MAC address Clone is enabled on Setup > MAC address Clone (click Clone, and Apply). If it's a DSL connection and your broadband provider gave you a username and password, select "PPPoE" for Internet Connecton Type, and enter in your DSL username and password. Next verify if your modem is communicating with the router by going to the Status page and by verifying that you have an Internet IP address. If none, wait for a few minutes and power cycle your modem and router.
Dec 11, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Finding a local area connection
Is this a wireless connection?
If yes than most of the times the problem is that the signal is weak, try to put your Router/AP to a better place and see if you can connect, netstumbler can give you a hand in this, not sure if it's working under vista or not, but under xp it's perfect. My experience ist that what you need to have at least is 15 For SNR for your Router from the place where you are trying to connect. If it goes under 10 it will drop you down.
Better SNR means stronger signal and that's all that matters with a simple wireless connection.
Regards
Imre
Nov 26, 2008 | Linksys Wireless-G Broadband Router
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Belkin N Wireless Modem-Router F5D8633au4A Logo
254 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
