Question about Kenmore 44832 Front Load Washer
Brown dirt-like looking "gunk" coming out of the washer
I have this wet, flaky, gritty brown substance that comes out of the washing machine in the water. I noticed it in the nylon I have over the hose to catch any lint, etc. It is very moldy smelling and disgusting. At one point, it was about a cup or so that came out. My clothes, don't have a moldy smell, but the inside of the machine does, when you stick your head in--I also get a sewer smell when it runs. I've been told it has nothing to do with the pipes, waterline etc. I tried running it with bleach and running it empty and the stuff keeps coming. It's a Kenmore Elite HE3 front loader. HELP!!
    President:
  • Kenmore Master
  • 662 Answers
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Posted on Jun 03, 2010
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
I find pieces of brown paper-like substances in my washer after each washing.
try experimenting with a liquid detergent as that is sometimes the result of power residue build up in the machine
Mar 07, 2012 | Maytag Washing Machines
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
Oil smell in washing bowl, wet pump exterior and floor puddle.
Mark, the "brown stuff" is a build up of old soap, dirt and often mildew. Yea, gross huh? The best way to get rid of it if you have a bad case (which sounds like you) is to remove the spin basket and actually clean all the crud out. Once it has been cleaned then you should do at least 1 load of wash a week on HOT and it helps keep the gunk away. Some places offer products that are supposed to remove the gunk but I have yet to find one that does. The brown stuff is not related to a bad seal on the shaft. Good luck!
Aug 11, 2009 | Fisher Paykel EcoSmart GWL15
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Kenmore goo/gunk
If it's a front load washer do not put to much soap in it!This can gunk it and cause the bearings and seal to go bad!
Follow the washer directions for detergent amounts.
PS . Please give me a good rating here on fixya.com
Thank You ngfam2
Aug 22, 2008 | Kenmore 44832 Front Load Washer
Grimy brown residue
the leveler and universal need to be repaced these are the parts underneath the plate in bottom ..residue and corrision are coming off and getting redeposted inside also cke recirculating tube right rear sometimes gunk will accumilate there but my money is on the universal and leveler both come in a repair kit
May 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 44832 Front Load Washer Logo
1,401 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
