Question about ViewSonic Computers & Internet
I get a no analog signal with the viewsonic VA1930wm and screen goes black
When booting computer, i get a black screen and a no analog signal
  • 4 Answers
SOURCE: Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Posted on May 19, 2008
SOURCE: I have a viewsonic vg2021,
Hi grazerone,
That typically happens when there is no video connection between the pc and the monitor. Are both sides plugged in?
Alternatively you may have put the interface cable into the wrong socket on the video card.
Regards,
Ebek
Posted on Dec 19, 2008
graemevm
  • 519 Answers
SOURCE: ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Posted on Jun 12, 2009
celibytes
  • 70 Answers
SOURCE: Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Posted on Sep 10, 2009
SOURCE: After starting the computer the screen is black
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Posted on Dec 02, 2009
Power light on monitor lights but screen is black. Is it done?
This can happen if you somehow changed the input setting. Make sure to check the "Input" setting on the on-screen menu and make sure it's set to the proper type of input (HDMI/Digital or D-Sub/Analog) for the cable you're using. If that is correct, and you don't get an image, then you should also try to connect your monitor to another computer using another cable...because it actually may be your computer's video output, or a bad cable, that is the problem, and not the monitor.
If those checks don't solve the issue, then yes it may be "done."
This link will provide you with a user manual for your monitor to assist with the on-screen menu selection.
Jan 08, 2011 | ViewSonic VA1930WM LCD Monitor
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
My viewsonic monitor goes black after booting up
Does it do the same with other PC?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | ViewSonic VA1930WM LCD Monitor
Screen Blinks image on & then goes black.
Does it do the same with other PC? I assume you are using VGA DB-15HD cable, not the Digiltal DVI.cable. It can be failed component inside the monitor but you need to narrow down the problem first. If you are going to DIY repair, please read below and also look through the failed VIEWSONIC monitors so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | ViewSonic VA1930WM LCD Monitor
Monitor on but image from pc come in for a second, and get screen black
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | ViewSonic VA1930WM LCD Monitor
I have a viewsonic va1930wm. it turns off and on. how do i fix this
Is ur graphic card ok?
Have ur screen tested on another PC to determine exact cause...
Feb 06, 2010 | ViewSonic VA1930WM LCD Monitor
Viewsonic VA1930WM
You need to isolate the problem to see if there's a problem with the monitor or with the sound card of the computer.
To isolate this problem, please try the steps below:
1. Make sure that the monitor is properly connected to the computer.
2. Check the volume of the monitor and the volume properties of the computer.
3. Try to connect your monitor into a known working computer.
Apr 15, 2009 | ViewSonic VA1930WM LCD Monitor
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
46 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
