Hardware failure On startup, it restarts itself several times, when it finally stays on the colors are all wrong, Occasionally comes on right. When I send error report, it comes back from microsoft as a computer hardware failure. Computer is about 9 years old and has been upgraded several times, latest as Windows XP (which I love). Any help, or just time to buy new?
    Champion:
  • 209 Answers
Yes that is a hardware problem, your video card seems to be malfunctioning, if that is newly upgraded you need to install its driver in order to function correctly. and if the symptoms persist you need to install a new video card or try the on board video card
Posted on Jan 12, 2009
How do I repair a system that boots to the Windows 7 logo and then reboots itself a second time?
I agree (in part) with "map9966's" answer, but instead of trying to blindly load the "last known good configuration", You really should try the Windows Startup Repair option. This option should also be located in the "safe mode" menu, which again access by repeatedly pressing F8 right after turning on the PC. Once you get to the menu stop pressing F8.
Using the arrow keys on your keyboard, highlight the choice which reads (something to the effect of) "startup repair". The PC then *should* "boot" to the start up repair mode. This mode is an automatic utility, and can take anywhere from 15 minutes to an hour, depending on the speed of your PC, the severity of file system damage and the underlying cause of your start-up loop. Let the utility finish, (again, this WILL take awhile.. go have yourself a snack, take a walk, watch some TV..) Once it's done, restart the PC.
In most circumstances (assuming the start-up loop isn't due to a hardware failure), your PC should boot up just fine. If you have any further questions, feel free to contact me!
Sep 14, 2014 | Gigabyte GA-MA78GM-S2H (rev.1.0)...
My Asus motherdoard P7P55LX, Core i5 System is restarting at startup
It would appear that the RAM installed has problems. One of the RAM modules is most likely defective or does not want to work with the other. Module incompatibility is rare, but does occasionally occur. Try running the machjine with just one of the RAM modules installed at a time. This may help you isolate the defective one.
Jan 06, 2012 | ASUS P7P55 LX Motherboard
Check engine light stays on. Occasionally esc comes on and engine will not idle up. After restarting several times, usually works again. Have checked gas cap but don't know what else to do.
Take your battery termenial of for 15 min. and it will reset your computer and if it comes back ojn you will have to take it to the garage and let them hook it up to a computer to see what is wrong with it.
Jan 21, 2011 | 2007 Hyundai Santa Fe Limited
Asus U52F laptop -- 1 week old, a few days ago the internal wifi network adapter started randomly shutting itself off here and there throughout the days. Occasionally it switches itself right back on, but...
Sounds like a faulty wireless card or the card is installed with the wrong version driver.The wireless card itself sounds to be bad and needs replacing
Jan 10, 2011 | ASUS U52F-BBL9 Laptop
When I start my computer it shuts down and reboots about 4 times before it will finally start properly
Hello
A computer that constantly reboots can have one of several issues, and can be hard to troubleshoot if it will not stay on. Viruses and spyware can cause the computer to reboot continually, but hardware failure or power issues can also be the root of the problem. There several ways to approach the troubleshooting process.
Hardware failure can cause a never-ending reboot cycle; eliminate the most common causes first. Replace memory chips one at a time to rule out a bad stick of RAM. If the memory checks out, boot from the Windows CD and access the Recovery Console. Run chkdsk /R at the command prompt to check for problems with the hard drive. Remove any optional cards that were added in to the computer (such as a sound or network card) to eliminate them as the cause.
Press the F8 key while the computer is starting up to access the advanced start-up options. Select "Last Known Good Configuration," and press Enter. If that does not work press F8 again, and select "Safe Mode" this time. If you are able to access Windows in Safe Mode, disable the option to automatically restart Windows after system errors by right-clicking on the My Computer icon and selecting "Properties." On the Advanced tab, click the "Settings" button under "Startup and Recovery" and clear the check box labeled "Automatically restart." This will allow you to restart the computer without getting stuck in the reboot cycle. Ensure that your antivirus and antispyware software is up-to-date, and perform complete scans for any infections. Remove any newly installed software that may be incompatible with Windows, and update drivers for your hardware.
Replace the power cord to the computer, replace the power strip it's plugged in to, and try a different outlet. If nothing else helps, try a new power supply. Be sure to purchase one with enough power for your computer: use a high-performance power supply for a gaming computer or a lower-performance power supply for a regular workstation.
Nov 13, 2010 | Microsoft Windows XP Home Edition
My dell lcd monitor will not stay on
If the problem related to wrong PC (video adapter) settings, during boot-up, right after BIOS started, press F8 button to call OS startup menu, choose there 'VGA Mode', then OS will be loaded with basic VGA settings (640x480 250 colors), so you will be able to set other display settings, proper for your monitor.
But all that, of course, won't be possible if the monitor itself shuts down, that would be completely different story.
Confirm what exactly is wrong, Display Settings or the monitor itself?
Sep 05, 2009 | Dell E176FP 17" LCD Monitor
LCD showing wrong colors
I believe it might be dieing. you can get a 19 - 20" for around 120 - 140$.
May 21, 2009 | Acer AL1716 17" LCD Monitor
My ELO touchscreen stays black, but the beep works
backlight problem you need to replace the backlight
Aug 13, 2008 | Elotouch 17" LCD Monitor
Acer Aspire 9300-3655: Shuts Downs When Idle
It sounds like you are getting a blue screen error.
Most of the time these are resolved by manually running CHKDSK /R
To check for a blue screen error, right click on "My Computer"
Go to properties, click on the "advanced" tab, Click on the "Startup and Recovery" settings button.
Under "System Failure" uncheck "Automatically Restart"
Now if your computer is restarting do to an error then you will see the blue screen.
The important information to give back is the 0x000000** part which is displayed.
Mar 14, 2008 | Acer Aspire 9300 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
