Question about Kodak Easyshare C813 Digital Camera
I can't use this thing
Kodak Easy share C813-will not turn onWhen connected to my PC I get a signal that it is on, the sync works and the SCreen lights up and reads Sync, but the computer isn't able to retrieve any data.
  • 1 more comment
  • Anonymous Jan 10, 2009
    i have the same Problem
  • irockipodbab Jan 15, 2009
    mine wont turn on or anything i need help with that...
  • blueextc3221
    blueextc3221 May 11, 2010
    is this a new problem? Has it worked in the past? What OS are you using?
The kodak c813 is just plain defective,what's wrong with this company for putting out a camera that won't work,we need a class action
Posted on Jan 15, 2009
MY COMPUTER CRASHES EVERY TIME I TRY TO UPLOAD PICS AND THEY WANT UPLOAD HELP THIS HAS SHORT VIDEO CLIPS AS WELL IT WILL GO THROUGH THE PROCESS OF SEEING IF THERE ARE DUPLICATES AND AFTER THAT IT ACTS LIKE...
Please reinstall your version of Easy Share software:
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Jan 12, 2010 | Kodak Easyshare C813 Digital Camera
HOW TO UPLOAD VIDEOS FROM THE CAMERA KODAK EASY SHARE C813
First install software and drivers, then run easyshare program, then turn on camera, then lastly hook up with usb cord.
Oct 01, 2009 | Kodak Easyshare C813 Digital Camera
Kodak easy share C813, the display is over saturated
Using exposure compensation to adjust picture brightness Before you take a picture, you can adjust exposure compensation to make pictures darker or lighter.
The exposure compensation level is shown on the LCD; the LCD gets brighter or dimmer.
OR
You need to upgrade the firmware.
Download this file to your pc and follow the instructions:
Firmware Download
Installation Instructions IMPORTANT: Print this page before continuing.
Prepare your Camera CAUTION: Loss of power during the firmware upgrade can render your camera inoperable.
  1. Connect the optional KODAK AC Adapter, or install a new or fully charged battery in the camera.
  2. If you have pictures on the internal memory of your camera or on a memory card, save the pictures to your computer.
Download and Extract the Firmware File
  1. Download the file to your computer.
  2. Double-click the file to start the WinZip Self-Extractor.
  3. Select Unzip to folder, and specify a location, or leave the default location.
  4. Click Unzip. The firmware file unzips to the specified folder.
  5. Note the location of the folder. The file has a .fw file extension.
  6. Close the WinZip Self-Extractor.
Select a Method
  • If you do not have a memory card and card reader, use Method 1.
  • If you have a memory card and a card reader, use Method 1 or Method 2.
Method 1
  1. Visit the EASYSHARE Software Web page at www.kodak.com/go/easysharesw, and download the latest version of software.NOTE: EASYSHARE Software version 6.x or later must be used during this procedure.
  2. Remove the memory card from the camera.
  3. Turn on the camera.
  4. Format the internal memory of the camera:
    1. Press the menu button.
    2. Select Setup.
    3. Select Format.
    4. Select Internal Memory.
    5. Press OK.
    6. Press OK to continue.
  5. Connect the camera to your computer using a USB cable.NOTE:The first time you connect your camera to your computer, Sync andTransfer Setup or Sync and Transfer Assistant prompts appear on thescreen. Follow the prompts to set up the camera as a device in thesoftware.
  6. Start EASYSHARE Software.
  7. Select Tools > Sync and Transfer Manager.
  8. Select your device from the list in the left column, and then select the Info tab.
  9. Click Update Firmware, and go to the location where you downloaded the firmware file.
  10. Click Open to copy the file from your computer to the internal memory on the camera.
  11. Turn off the camera, and then disconnect the USB cable from the camera.
  12. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  13. Turn off the camera, and then turn it back on again.
Method 2
  1. Remove the files from the memory card.
  2. Place the memory card in the card reader.
  3. Open the drive corresponding to the memory card to view the card contents.
  4. Check that a System folder exists on the memory card. If not, create one.
  5. Locate the firmware file on your computer and copy it into the System folder on the memory card.
  6. Remove the memory card from the card reader, and insert the memory card into the camera.
  7. Turn off the camera.
  8. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes.
  9. Turn off the camera, and then turn it back on again.
Sep 10, 2009 | Kodak Easyshare C813 Digital Camera
When i turn my kodak easy share C813 on it says
take out the battery and set your mode dial to auto and put the battery back again and turn on your camera.
Aug 19, 2009 | Kodak EasyShare CD33 Digital Camera
My kodak easyshare C813 WONT TURN ON!!
After searching and getting the run around, the only solution I've found is to BUY a new camera that IS NOT Kodak!!! I had never had a problem with Kodak until now...I WILL NOT buy this brand ever again!
Apr 03, 2009 | Kodak Easyshare C813 Digital Camera
Camera wont turn on
pull out slightly with a pin the two gold contacts on the battery door
Jan 27, 2009 | Kodak Easyshare C813 Digital Camera
Try reversing the the way the batteries are installed.
The way the positive and negative terminals are aligned
is very confusing on this model.
Oct 31, 2008 | Kodak Easyshare C813 Digital Camera
Help Turning my camera On
Hi , I had the same problem ,Kodak advised getting re-chargable batteries Mah 2500 ,normal batteries just are not powerful enough. Mine works fine now
Aug 31, 2008 | Kodak Easyshare C813 Digital Camera
Downloading photos
Hi, Most present day digital cameras are recognizable by a Windows PC as an external removable drive. You have to connect the camera using a USB cable (in some case, a firewire cable) to any of the USB ports of your computer. Give your machine a second or two to recognize and auto-install the needed drivers/software. The PC normally auto displays content of the camera (now recognized as possibly drive "E" or something). Thereafter it is a matter of copy/paste or drag-0n-drop to your preferred folder in your PC (more often My Pictures inside My Documents). Hope this be of some help/idea. Post back how things turnedout or should you need furtherinformation. Good luck and kind regards.
Sep 16, 2007 | Kodak Easyshare C813 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
120 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
