Question about Vizio L32 32 in. LCD HDTV
Connecting COX DVR and Phillips DVD to Vizio HD TV
I am trying to connect the Vizio to the COX DVR cable box, and would also like to watch DVDs on occasion, so I am adding the Phillips DVD player. I am unable to find the correction connection to make this combination work.
  • Anonymous Mar 30, 2014
    It detects some wifi connections but when I put in the password it says unable to connect.
We connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
Posted on Jan 12, 2009
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Jun 02, 2009 | Vizio VX37L Television
This manual might work for your remote. It does not have codes for Vizio either but does have the procedure for Finding codes not listed on PAGE 20. Go through that procedure which can find codes that will work.
Jan 20, 2018 | Televison & Video
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Am setting up a bose GSX 3-2-1 home theater
simplist solution, if the TV has an audio output just run that to the Bose system.
what type of TV are you connecting to?
Is the cable box an HD or digital box?
Jun 23, 2008 | Bose Cinemate Digital Home Theater System...
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Watching T.V. with speakers
Component 1 on the TV is probably an input, not an audio output. You need to find out if your TV has audio output jacks.
If I'm mistaken, and you are using audio output jacks from the TV, then you just need to press FUNCTION on your remote until the LCD display says "TV/VCR".
Apr 28, 2008 | Sony DAVHDX265 System
Vizio L32 32 in. LCD HDTV Logo
810 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
