Question about Tamron AF 28-200mm f/3.8-5.6 LD Aspherical Lens
Will my tamron af ld if work on a digital camera
Will this lens work on a digital camera? currently on my nikon F65
4 Suggested Answers
  • 102366 Answers
SOURCE: Tamron 200-500mm F5-6.3 SP AF
Assuming the lens has a Nikon mount, yes.
Posted on Dec 02, 2010
  • 175 Answers
SOURCE: Tamron AF 28-200mm 3.8 - 5.6 Apherical LD that was
It will fit but no AF.
Posted on Jan 06, 2011
Tri3mast
  • 747 Answers
SOURCE: Drop my Nikon D100 camera with a Tamron AF
First question "is it worth repairing" if it were mine I'd look to see what a new one is worth then divide that in half (cause that's what you might be able to buy a used one for) then figure about $120.00 for cleaning lubricating and adjusting the your lens. With your lens you know what you have, buying used might need the service. you are the one to decide. As for the second question "can I repair it myself" short answer no. If you have to ask if you can repair it then you don't have the necessary tools and general knowledge of how to dismantle and reassemble the lens (and have it work when finished). The lens took a hit and most likely set the inner and outer lens barrels out of alignment causing the inner barrel to slip out of its seal and or focusing gear and hang things up forcing it will break parts causing more repair costs. All else fails get an estimate before repair. Been there with a lens myself and after a couple a months without bit the bullet and had it repaired. Cheers best of luck
Posted on Jan 28, 2011
Tamron service manual
See if this site is of any help
http://camera.manualsonline.com/manuals/mfg/tamron/tamron_camera_lens_product_list.html
Jul 02, 2014 | Tamron 70-200mm f/2.8 Di LD IF Macro AF...
What nikon camera will this mount to
Tamron is a third party lens manufacturer and make lenses to fit all popular makes of cameras both film and digital. I'm sure the top two would be Canon and Nikon. So if the lens you have there is a Nikon Mount it will fit Nikon Auto Focus cameras both film and digital
Jan 04, 2011 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
I just bought a tamron di 2 AF 55-200mm f/4-5.6 LD macro for my nikon D40 and i can't get it to autofocus
That 2x is not AF-s compatible. It is the older Af style which the d40 does not support. Your camera store should have known this when they sold it to you, unless you bought it mailorder. Then see if they will let you return or exchange it.
Nov 04, 2009 | Tamron Autofocus 2x Teleconverter Lens for...
Nikon D40x
you will not have AF...only MF
full list of compatible lens for your camera here
Oct 16, 2008 | Tamron SP AF 11-18mm f/4.5-5.6 Di II LD...
Tamron 28-300 lens broken off from camera
Hi: The only way to have this lens serviceable is by having a qualified tech repair the lens mount. You can contact the folks at Tamron's service center and ask for an estimate. Good luck: theboyd
Oct 15, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Tamron lens and canon speedlite compatibility
Your question is posted under a Nikon version of this lens. I assume you are talking about using the Canon EOS mount version.
The short answer is: Yes
Jan 15, 2008 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
Cameras Logo
20 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
