Question about Sony PlayStation Portable (PSP) Console
Computer wont recognize psp?
I connect my psp to the computer and it wont recognize it. i choose the usb connection but it still wont work what do i do?
Try a different computer or different usb cable.
Posted on Jan 10, 2009
My computer dosent run my psp program with a usb cable so i can sync anything in, how do i make it recognize my psp
When you connect your PSP to your computer, it won't recognize the PSP immediately. After you connect the PSP, you will have to navigate to USB Mode on the XMB. Your computer will recognize your PSP as a mass storage device.
Good Luck.
Mar 18, 2011 | Sony PlayStation Portable (PSP) Console
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My laptop wont recognize my psp at all!
Normally when you connect usb from your computer it will automatically detect you psp.
The otherway is connect your psp using usb cable to your computer and then go to setting and choose USB mode. it will automatically view the folder of your psp.
Nov 27, 2010 | Sony PlayStation Portable (PSP) Console
How do I connect a psp to a laptop with a usb cable
Hi agatha_12301,
These are the following steps on how you can connect your PSP to a laptop:
1. Using the USB cable connect PSP to your laptop. Just make sure that both ends are properly connected.
2. Once connected, On your PSP look for SETTING. After selecting it, choose USB CONNECTION.
3. Afterwards your PC will start to detect and will soon recognize your PSP. Laptop will prompt the drive for your PSP (ex.drive F:).
4. Just double click on the specific drive for your PSP. From then on, you can start transferring files or anything you wanted to do.
Hope it helps.
Oct 31, 2010 | Sony PlayStation Portable (PSP) Slim...
I want to connect a cctv camera to psp
yes indeed. you need simply a usb to mini usb hub cable ( about 15 bucks) and hook it in, go to usb mode on the psp it will have a few options. naturally th epsp wont recognize the system immediatelt, so give it time and all will be solved. if this doesn't work, then i recommend changing psp settings on your computer to allow the psp tpo recognize it immediately.
Apr 19, 2009 | Sony PlayStation Portable (PSP) Console
Computer does`t recognize psp
try to use another usb connector cable with your psp. It has some lost connection...maybe the data connector is loose. USB has 4 pin(pc side) the voltage supply for power and the data pin..just try.. if it doesnt work...checked if your in admin account because some hardware cant be installed if your not the admin of the pc.
Apr 13, 2009 | IBM ThinkPad R40 2722 Notebook
Psp
Connect your PSP to computer using a USB cable that came with your PSP. After you did that, On the PSP, click the "USB Connection" button (on the Settings menu).
You will see that the computer recognized it if you go to "My Computer". From there you can see what is on your memory stick, copy it, delete it and so on..
Hope that helps.........
Aug 12, 2008 | Sony PlayStation Portable (PSP) Console
USB fails to recognize my PSP
what are you trying to do? connect it to the computer?
if so try a new usb cable. if that dont work look inside the female ubs jack on the psp make sure all the pins are there. see if it wiggles any.
you might need to replace the ubs port on your psp. which is a soldering job.
contact us for professional help. United.Gamez@Gmail.com
May 24, 2008 | Sony PlayStation Portable (PSP) Console
Psp
* Make sure you have inserted a memory stick, and enable the usb connection via settings=>usb connection
* Check the usb cable, or simply find another one to try if it works.
* If there is a memory stick inside the psp and the psp can recognize it, then you most probably have a problem with your cable or usb port.
* if there is a memory stick inside the psp and the psp cannot recognize it, as well as the computer, then you are most likely to have a failure with your memory card.
There are too many possibilities, maybe you can give me details straightaway, so more people can help you.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
