Question about Exercise & Fitness
I have the Ifit tread mill not sure what model, but when you Are running or walking on it and put your foot down it will pause. What can I do to fix this problem?
    Top Expert:
  • 12,223 Answers
This happen because the lack of maintenance LUBE. Now you need to lube the deck belt, probably you have WORN deck belt.
2) LUBE the rollers bearing too.
3) Test the drive belt motor, for worn, crack or adjust if possible.
4) Test the input voltage motor, if there are the Motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
I have the Ifit tread mill not sure what model, - 11_28_2012_3_54_44_pm.gif11_28_2012_3_54_59_pm.gif
Posted on Nov 28, 2012
  • 40 Answers
SOURCE: ihave not use my tread mill about two month, now
Many possiblities, but likely a bad motor control board.
Posted on Sep 29, 2009
  • 33 Answers
SOURCE: the belt on the tread mill slips while operating
hai ,check the walking belt and motor belt tension
Posted on Oct 01, 2009
SOURCE: walking belt on image 10.0 tread mill slips,
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Posted on Feb 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
Walking on tread mill is jerky. almost like some one keeps putting the break on
Hi There, have you lubricated the deck lately? does the belt glide easily over the deck with your foot pushing it and the power to the treadmill off? If the belt glides easily with your foot, but not when powered, you're motor control board could be about to fail. capacitors routinely go bad on these controllers over the years. You can find further help by emailing gregATbuyfitnessrepairpartsDOTcom
good luck!!
Feb 07, 2016 | Bladez Ion 9.9 Fold-up Treadmill
How do I tighten a slipping belt
My tread mill has a bolt on each side at the rear end that I put a hex key in and turn to tighten. Do both sides the same to keep the tread even on the track. Don't over tighten. I have a different make but most operate the same.
Oct 14, 2014 | Sportcraft Tx 4.9 Model 4041 B Walking...
Owners manual iFit 520 pro form tread mill
Go to website: www. proform.com
then go to customer services and then part -manual give you model, etc, and download for free.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA
Nov 28, 2011 | Exercise & Fitness
What's your problem?tread mill stop working belt stopped turning
Dear Sir:
Hello I hope you are o.k
After Reading your problem, I will help you please follow the next step:
Your problema is Electrical:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
If you have questions, email us at doc@treadmilldoctor.com
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill (if
equipped) trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix (that we don't recommend) try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact me with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel . Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or a console.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
I recently purchased a Bowflex treadmill and while I was walking on it, it stopped working and shows the error message "Safe Out" on the console. The safety button is in place and I tried...
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Dec 26, 2010 | Bowflex Exercise & Fitness
I have a singer model 3116 and the tread keeps getting bogged down on the back. how do i fix this problem?
You need to rethread, now put the presser foot up, pull on the top thread. then lower the presser foot, pull on the top thread, it should barely move. This should seat your thread in the tension discs. Also, make sure that you have a fresh needle inserted the right way, flat side to the rear of the machine. Good luck
Nov 21, 2010 | Singer 3116 Simple
My tread mill looses speed during my workout. the
Apr 10, 2010 | Proform Exercise & Fitness
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
