Question about Dryers
SCHEMATIC FOR AMANA DRIER NED7200TW
I need to see the schematic and parts pictures and parts numbers. The manual will not download on my computer. I don't want to order the wrong timer knob. Thanks.
    President:
  • Dryers Master
  • 1,932 Answers
Hi ,
You cannot jus change the timer.You need to change the user console and display board fully.
Here is the part.Can order online.
http://www.repairclinic.com/PartDetail/User-Control-and-Display-Board/35001269/1185581?modelNumber=NED7200TW10
Here is the parts manual
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NED7200TW10/1268/0151200
Thank You
Posted on Nov 28, 2012
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
  • 958 Answers
SOURCE: my gas dryer's igniter glows,
im sure the theory would be the same as the whirlpool, in the whirlpool, they have this flame sensor, if it senses the heat from the igniter, the it would open the solenoid valve to release the gas to ignite and hold it open as long as there is flame present.
it could be a defective flame sensor.
cheers,
drcool
Posted on Aug 02, 2008
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Fix-Fox
  • 7 Answers
Here you go again :-)
hunter19_46m
  • 7482 Answers
SOURCE: I am in need of
Hi jenflint78...
Try some of these solutions first...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 27, 2011
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
It keeps showing an error code C0. what does this mean.
Hi, I cannot find this error code for your dryer.
Does the dryer have other faults?
The Technical manual for the drier shows error codes, but does not include CO. The manual will help with resolving problems you may have as it has detailed instructions for troubleshooting and the solutions. See the diagnostic tests. You can also clear diagnostic codes, which may resolve this problem if there are no other problems with the drier.
You can download the manual from
http://www.manualslib.com/download/763426/Amana-Ned7200tw.html
Hope this helps you :)
Mar 04, 2015 | Amana NED7200TW Electric Dryer
I need to find a schematic of where the thermal fuses are on the Amana NED7200TW
Most like it will be a fuse thermostat #13, or thermister #27 check and see if they look damage (burnt) and with a voltameter check if there is continuity, if they look good move onto the heater coil if it does not heat check the continuity of it, if the coil has a reading then it should be good if does not then it might be damage. Replace parts that look damaged. Here is a link for parts As for the motor, does the drum spin, if it does the the motor is not damaged.
Sep 06, 2014 | Amana Dryers
What does it mean if my drier smells like gas?
It means there is a leak. You should turn off the gas flow to the drier immediately until it is fixed!
May 11, 2014 | Amana NED7200TW Electric Dryer
How to access belt pulley
Hi James Williams
You will have to remove the top/front of the dryer and then remove the dryer drum from the inner case.
Go to the following webpage and you can see a schematic of your dryer, it will be easier to take a part and reassemble with this schematic.
The company also has parts and a toll free number
Please take time to rate me
Bud
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=NED7200TW10&mfgModelNum=&fkMfgID=1
You should view this Youtube video, it is not your model dryer, but it will give you some very good ideas how to take yours apart and access the belt pulley.
http://www.youtube.com/watch?v=PY8DgdTbomQ&playnext=1&list=PL7F004559A84354DB&feature=results_video
Oct 10, 2012 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
Amana sxde25j high voltage board blown..
hi there,
you can try to this store to order the parts to be replaced part number & description was also indicated in HERE.
just let me know, for further assistance,
Apr 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Dryers Logo
242 people viewed this question
Top Dryers Experts
