CANON IR 2525 ADF PAPER SIZE - Office Equipment & Supplies
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
SOURCE: Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Posted on Jan 26, 2008
SOURCE: Canon PC980 ADF PROBLEM
not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: It senses paper loaded into the ADF but doesn't feed
There should be a button with settings on it.....ie: 2 sided, collate, etc. There should be an option to change paper settings.......or just clear the whole menu, and go to default to reset the rollers.
Posted on Oct 20, 2009
  • 92 Answers
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
Posted on Nov 02, 2009
Canon ir 7095 copier ADF too much paper taking in one time.
Check the paper thickness. It can be a problem. try with another paper.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 14, 2016 | Canon imageRunner 7095
Cannon IR 2525-2530 wont print
check the console menu for problem indication code, most common mech problems are paper jam, paper tray empty, and low ink. Most common user side problem is non-connection from source to printer. Check print settings to ensure the IR2525 is still listed and selected.
Jan 28, 2014 | Canon BU-20 (13803055436) Print Server
Canon ir 2525 service manual & parts catalog
Please refer your request directly to Canon
Apr 18, 2013 | Canon IR 2525 Digital Copier
Bottom half portion of the paper horizontally gets black (dark)
I would presume that somwheare beneath adf is light coming to scanner. Try to adjust height and possition of adf on adf hinges.You have two screws, one for height, and other for left or right possition.
May 25, 2010 | Canon imageRUNNER 5000 Copier
Canon LASER SHOT LBP-1210 Printer how to set legal page
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties "Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
Apr 24, 2010 | Canon LASER SHOT LBP-3000 Printer
Problem ir 5570
First check the settings in the paper cassette of the machine and make sure it is correct paper setting set for the tipe of paper.Check the paper detection sensors on top of the dadf and test -if you push them down they must return instandly.If the sensors take a while to return to home possition,the copier calculate a diffrend papersize.
It also help if you blow the dadf with compressed air.
Good luck
Jul 03, 2009 | Canon imageRUNNER 2270 Copier
Regards DADF size setting in ir4570
Are you sure the problem is not coming from the paper tray????
Open the paper tray and look at the guides that hold the paper, if Letter paper is in tray make sure the guides are set against the paper, also look "behind" the tray for paper it could be changing the paper size.
Oct 03, 2008 | Canon imageRUNNER 4570 Copier
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
44 people viewed this question
k24674
jasbo
jasbo
