Question about Refrigerators
My westinghouse Silhouette 303 freezer alarm light is on and it wont work
Transported it yesterday and switched it back on today but only alarm light came on
3 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
Posted on May 19, 2009
martineznoe8
  • 92 Answers
SOURCE: I have a westinghouse silhouette frost free
THE COMPRESSOR IS NOT WORKING ON YOUR REFRIGERATOR..
Posted on Feb 17, 2011
After defrosting, red alarm light on, green power light off. Westinghouse Silhouette FR393Q freezer.
Alarm means that the unit is overtemp for a freezer. Your breaker was likely overloaded if the same issue didn't follow the machine to the next outlet... If the alarm stays on when the unit is clearly freezing, you have some type of control problem. That model number is incomplete/incorrect.
May 25, 2016 | Refrigerators
What do we do about a Westinghouse , vituoso where the freezer alarm keeps going off despite an expert checking and finding the fridge/freezer working perfectly well? Can the alarm be disabled?
The alarm is nothing more than a buzzer or light mechanism that is triggered by some sensor. . Disconnecting the wiring going to alarm will disable it.
Sep 25, 2015 | Westinghouse Refrigerators
Why do lights flash while on trailer on 2014 street glide
The bike senses movement (like someone is stealing it) and activates the "Smart Security System".
You won't have an actual alarm unless you have the optional alarm installed.
You need to put it in "Transport Mode"
In the transport mode, the Harley-Davidson Smart Security System is armed but the motion detectors are inactive.
The motorcycle can be transported on a trailer without activating the alarm while the starter and ignition remain disabled.
Here's a video how:
http://www.youtube.com/watch?v=tA35I8RWI_s
And written instructions:
With an assigned fob within range, turn the ignition switch to IGNITION.
Before the security system lamp goes out, turn the ignition switch to OFF.
Within three seconds, simultaneously press both the left and the right turn signal switches.
After the turn signals flash once, the system enters the transport mode.
With the fob removed, the motorcycle can be moved without setting off the alarm.
May 18, 2014 | Harley Davidson FLHX Street Glide...
Why does my Kozy World natural gas wall heater set off fire alarm system?
Most new heaters give off a smell or some light smoke which needs to be burnt off the first time it is used it may smoke , this may be why your alarm is going off , run it with a window open to remove smell etc .
Feb 12, 2013 | Heating & Cooling
My Westiinghouse Silhouette Series 2 Frost Free 303 Freezer (Model No. FJ303F) appears to have blown a fan. My electrician is wanting a wiring a wiring diagram to facilitate repair.
what you need to do is get rid of the electrician, and get a refrigeration service man and he wont need the wiring diagram.
Feb 22, 2011 | Freezers
..Ihave a 2004 venture van.
sounds like water in somewhere ?? but where without my head under bonnet i couldnt say ,but its soaked something so perhaps it will be ok when it dries out
Sep 17, 2010 | 2004 Chevrolet Venture Passanger
Red alarm light came on after we defrosted a westinghouse freestyle vertical freezer. what ius causing this pls. wilf
red alarm light is telling you that the feezer is too hot
(above 18c)it should go out when powered up and back to normal temp.
Mar 24, 2010 | Freezers
RS Focus registered yesterday 19th March Keyless entry but remote fobs do not lock or unlock car. The car was driven back yesterday hav ing now covered 114 miles alarm was going off last night but thats...
should not be using fob buttons for entry or locking for emergency only .if keyless entry walk up to car with fob do not press any buttons see if door opens then walk away from car with fob about 20m then go back to car without fob and see if door locked if so all working fine .indicators will not flash if the above dont work take back to main dealer for diagnostics keys may need to be reprogrammed
Mar 20, 2010 | 2009 Ford Focus
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
