Question about Palm Tungsten E2 Handheld
My Tungsten simply will not switch off using the "off" button.
Is there an easy solution to this please?
  • Anonymous Jan 13, 2009
  • 4 Answers
Hi Hodgkin3...
You will need to do a HARD RESET on your Palm. BEFORE you do that make sure you do a HOTSYNC to save ALL information to your PC. Once you do a Hard Reset everything on your PDA will be wiped and restored back to the original setup that you had out of the box.
Once you have backed-up your Palm, hold down the OFF button while depressing the RESET button. You will receive a message on the display that ask if you want to reset the palm (as long as you are ready to wipe clean your PDA), reply YES.
Posted on Jan 16, 2009
Tungsten plate Manufacturing technique of
This "question" is an attempt at spam. It's not a very good one since it fails to provide any contact information so anyone who might be interested in their products wouldn't be able to get any.
Oct 21, 2013 | Motorcycles
I have a Palm Tungsten E2. I just got a new computer and downloaded the hotsync software from Palm in hopes to back up my Tungsten E2 by syncing it to the new computer. It is now asking me for a password...
Try using 0000 - that is four zeros - or 1234.
Those are the usual default passwords given by that manufacturer. When all else fails, contact the manufacturer! If you haven't already tried simply pressing the Enter Key with no password in the dialog box first.
Good Luck!
Dec 30, 2009 | Palm Tungsten E Handheld
Tungsten E: difficulty starting and turning off
PalmOne had a manufacturing issue in the Tungsten E and E2 PDA versions.
Bottom line is the On/Off switch is not properly soldered (enough soldering amount) so is easy that breaks the soldering joint of the switch to the main board.
The repair requires to open the PDA, remove very carefully the mainboard, and put straight (vertical) and re-solder the switch again.
It is needed a minimum of tools for it (soldering iron, torx screwdriver, wire soldering, plastic pry tool), and some skills and experience in fixing electronics.
Also, you can get with a radio or TV repair techniocian, and ask specifically to resolder such On/Off switch.
Best regards,
Jun 08, 2009 | Palm Tungsten E2 Handheld
Dead Tungsten E2 screen
Screen edges have come undone. Send in to have digitizer replaced. To attepmt it yourself could be futile
Dec 24, 2008 | Palm Tungsten T5 - Multilingual Handheld
Tungsten E will not get past Tungsten screen to sync.
Hate to say this but, back it up and toss it.
Nov 01, 2008 | Palm Tungsten E Handheld
Palm tungsten e will not switch on
Same problem. It just quit working. Power button does not work. Is there a battery I need?
Sep 03, 2008 | Palm Tungsten E2 Handheld
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Tungsten E
Hi : This means your battery must be as dead can be. Therefore it seems to be getting straight power only when you plug in the charger. Or your on/off button is dead. Are you able to turn it off/on when you have charge plugged. If so then I suggest getting a new battery for the E2 Palm and you should be back up and running. If this is not the case then it is your on/off button in which it could be just the contact or the switch itself. I can suggest someone in US if you like, else I can handle it but I am in AUS.
Oct 02, 2007 | Palm Tungsten E Handheld
Up-grading from tungsten E2 to TX existing SD card not recognised
What size SD card are you using? TX supports 2Gig cards with no prb. I did hear that some are having prbs with 4Gig cards. Also, make sure that the card isn't locked from being read, by checking the little slider knob on the card.
Oct 21, 2006 | Palm TX Handheld
Palm Tungsten E2 Handheld Logo
56 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
