Question about Whirlpool GR399LXHS Electric Kitchen Range
Stove top works, display unit and oven does not
Whirlpool Gold Accubake system, oven is controlled by the display unit, dispaly unit worked fine one minute then out the next
  • 1 more comment
  • Anonymous Jan 24, 2009
    whirlpool oven display does not work
  • Anonymous Feb 16, 2009
    how do i change the lower oven element
  • Anonymous Mar 28, 2014
    the oven doesnt work and the display panel dispalys pf
  • 31 Answers
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
Posted on Feb 08, 2009
My Whirlpool Gold Accubake, smooth top displays E1 - F1 (blinking). I am unable to utilize the oven because the push-button/ touchpad does not work however the electric burners work fine. Any clue? Many...
Hello, Thank You for using FixYa. I will be helping you today.This is erc or control failure. You would have to replace the electronic range control sometimes called the clock depending on your model number
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Ovens
Whirlpool Gold Accubake System smooth top stove keeps kicking out the 10 amp breaker, sometimes with oven on, sometimes just a burner on, just started doing this a week ago, why????
I have had teh same issue. Not sure if its a design issue or that is just how it works. I have replaced the element, the thermostat and the control board and it still does the repeated cycling.
Aug 30, 2010 | Whirlpool Kitchen Ranges
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GR399LXHS Electric Kitchen Range Logo
922 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
