Question about Hardware & Accessories
Stuck Door Knob with No Access!
The doorknob on my master BR closet is broken... the knob will turn but nothing happens. The door opens into the closet, so I cannot access the screws or the door hinges on the inside of the closet. The molding on the bedroom side of the door prevents me from sliding a credit card to move the latch. The knob has no lock, just a flat surface on the knob, but other bedroom doorknobs have a small access hole in middle of the knob to insert a small screwdriver or tool to open it from the outside. This knob does not, so I tapped a small hole in it & inserted a screwdriver - I can turn the mechanism inside but it won't free the latch. Tried WD40, but it didn't help either. There is also no release hole on the shaft side of the door knob to press to remove the knob.
At this point the only option I can see is to use a hacksaw to remove the door knob so I can access the hole and try to remove the parts with needle nosed pliers. I don't want to remove the molding either. Any other suggestions? Thanks!
  • Anonymous Mar 20, 2014
    Check what in my summary
    Scholar:
  • 35 Answers
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Posted on Jan 10, 2009
Door knob jammed
what side door on car or truck
is it the back hatch or wagon door
is there another door you can open
Oct 26, 2016 | Cars & Trucks
The set screw has fallen out of our doorknob and is lost. What can I use as a replacement?
Just go to the hardware store and get another set screw. They sell them individually in the hardware aisle.
Dec 21, 2014 | Locks & Locksmithing
Whirlpool AWZ 612 E13 Error code on hot wash
This happens to me as well when I use drying. After using the machine, when I want to reuse it I get this error "E13". Somehow I manage to make the machine pass the error...
Though I am able to open the door. Here is how I do it (be careful if there is a lot of water in the machine):
- turn off the machine by switching the program knob to "Off";
- wait a few seconds (5 to 10 seconds or so);
- turn the program knob to any program (e.g. Cotton 30);
- the machine will do several clicking sound;
- one of the clicking sound is actually the door unlocking, at that moment open the door;
- turn the knob to "Off".
Hope that helps.
Oct 30, 2012 | Washing Machines
Broken interior door knob door will not open.
well if you havent been able to get the cat out by now its dead but looking at the pics only way you can get in is by jigsawing the latch out
May 23, 2012 | Hardware & Accessories
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
I need to find a mechanism for a door handle where the knob is situated in the middle of the door (like european doors) ...any ideas where i can find this type of door knob and mechanism?
I am in the same boat here, mine is also in the middle of the door and my doorknob is broken. Ahh. I can still re-attach and open if I play with it. I have talked with several locksmiths who don't know what I'm talking about. I know my bolt mechanism was made by "Weiser" Home was built back in 1975. Have you had any luck at finding any help with this? From end of door to middle is 18" and the mechanism is 19".
Mar 09, 2010 | Top Knobs M826 Door Pull
Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
Feb 27, 2010 | Hardware & Accessories
Bathroom doorknob stuck in locked position.
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Nov 18, 2009 | Hardware & Accessories
The knob is broken
youve probably solved the problem by now but i would use a spanner or molegrips on the spindle to turn it, fitting a new one would have fitting instructions included.
Sep 28, 2008 | Amerock 3 Ring Knobs - BP1586
Hardware & Accessories Logo
2,699 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
