Whirlpool Ultimate Care II washer Doesn't move past rinse
I replaced the coupling and put it back together and now it went to rinse and stayed there not moving along in the cycle.
  • 2 more comments
  • ynbd15 Nov 28, 2012
    The lid switch appears to be working. Is which color wires should I check going to the timer. I don't have a schematic diagram and I'd like to determine if it is a wiring problem or the timer.
    model# LSQ9600JQ0
  • ynbd15 Dec 01, 2012
    I thought I had it fixed and then the water flooded the garage again. It has been suggested the timer, a siphoning effect, Pressure switch, backed up drain. There is an air gap between the drain hose so I rule out the siphoning, I cleaned the connections on the motor. I'm thinking it has something to do with the pressure switch. I'm not sure but it seems like its telling it to keep filling so fast that it overflows the drain and gets stuck because it never reaches the cutoff level.
  • Richard Roth
    Richard Roth Dec 01, 2012
    The timer will have nothing to do with it at all. First I would open the console and blow the pressure switch line to the tub out really good. It will either be the pressure switch or the water inlet valve. Only one of those two.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
SOURCE: Washer don't go through cycle
timer drive motor defective. replace it
Posted on Nov 16, 2007
Lumpy816
  • 246 Answers
SOURCE: Whirlpool Ultimate Care II washer
If it will perform all of the functions if you turn your timer knob manually, I would open the console and check for any loose connections, although from your description your timer motor has gone bad (only availible as the whole timer) It can be purchased from online from the manufacture or from a local parts store.
Posted on Jun 15, 2008
mikedurland
  • 481 Answers
SOURCE: Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Posted on Jun 28, 2008
ngafm
  • 166 Answers
SOURCE: Runs great stuck on rinse cycle
Peace,
ngafm to your rescue,
Yes it is in the dial and mechanism of the timer!
Things wear out! So is life!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 08, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool Ultimate Care II Washing Machine Rinse cycle not workin
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Let me know if you need further assistance. I hope this helps you.
Posted on Jun 30, 2009
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Doesn't spin fast enough to remove water from tub. makes a steady noise that doesn't get louder or softer just stays steady
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate Care II washer will not agitate or spin
Your lid switch could be the problem. It has 3 wires: black red which are hot and green which is ground. Unplug that lid switch and check for continuity between black and red with the lid shut. This video shows where the lid switch is located
May 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool untimate care II won't spin/agitate.......
Welcome gonecamping
Whirlpool/Kenmore- Weak Clutch Spring
If the clutch is slipping the spring is weak and must be replaced.
In the Whirlpool it could be this.
Or a door latch
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Peace,
You will be fine
Bless You ngafm
Sep 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Jul 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
