Question about Sharp 55R WP5H 55" Rear Projection Television
Turn tv on and it goes to a blinking view timer light
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: view timer is stuck on
take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Posted on Feb 25, 2007
premtech
  • 934 Answers
SOURCE: VIEW TIMER
Try unplugging the B+ to the convergence circuit and see if it will power up.. If so replace the convergence amps, two STK392-040 and check all the low ohm resistors.
Bill
Posted on Dec 28, 2007
rylee_smith
  • 8619 Answers
SOURCE: View timer blinking and TV
Hi
Thanks for using FixYa. The power supply of your sharp TV might have failed. It could be due to swollen/bulged capacitors on the power board. It can also be due to the Flyback transformer, which generates the high voltages(part of high voltage circuit). If you have disassembled the TV before then you can check for the swollen cap.s and also for any loose connector cables from power board to other boards.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Posted on Oct 07, 2009
  • 55 Answers
SOURCE: view timer keeps blinking..tv wont turn on
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!)
Posted on Apr 14, 2010
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
The tv starts to come on,then goes of and the
off the sleep,standby timer mode on your TV.. you just check all the timer then turn it off.
Mar 27, 2010 | Televison & Video
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Turn on and turn off
my tv wont' turn on also light blinks 10 times
Jul 27, 2008 | Samsung PCN5425R 54" Rear Projection...
TV Problem
the red blinking light is a code that tells you what is wrong it will blink from 1 to 10 or just blinks all the time
Jan 03, 2008 | Sony KV-32S26 32" TV
Fast blinking timer light and tv will not turn on
it sounds like the 1000 mfd 16vdc caps on the dm board have gone bad, but with out a model number it is hard to be sure..
Nov 29, 2007 | Televison & Video
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
View timer is stuck on
Feb 16, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Sharp 55R WP5H 55" Rear Projection Television Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
