Question about Bosch RotoZip Spiral Saw RZ10 - 2100
The shaft lock on my Rotozip RZ5 is locked and stuck.
The shaft lock was being difficult to get unlocked but it finally did so. I noticed it sounded loose but got the unit ready to some routing. Then while I was using it, the shaft lock fell out of the unit. I put it back in and now it is completely stuck. I see someone else had this issue and the recommendation was to "split the housing". How do you do that? Before I came to this site, I had removed six screws on the housing but I couldn't see how to get into the unit afterwards. It looks like a solid casing (or am I wrong)?
2 Suggested Answers
vincob
  • 718 Answers
SOURCE: Trying to get blade off
Try a little PB blaster penetrating oil and a little more muscle not to much!! Nut might be a tad bit rusted in place. Good Luck....
Posted on Apr 21, 2011
Rotozip ZM3 Zipmate lock button is stuck in down slanted position. This is the 2nd one that this has happened. A home depot rental person took it apart and supposedly fixed it but when we tried it again,...
There appears to be a broken/ missing spring under the button that is causing the fault. Probably best to have a agent for the machine carry out the repair as a hire shop will only repair at the least possible cost.
Feb 15, 2013 | Omega Rotozip ZM3 Zipmate Attachment
I need rotozip bit change instructions
Press in shaft lock button, use supplied open-end wrench to loosen collet--RH thread and remove bit by hand.
Jan 31, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
I was cutting 1/4" wall tile. On the 3rd or 4th cut my rotozip RZ5 quit working. There is power at the outlet. The machine was pretty warm. Is there a fuse or thermal reset or do I need to send it in foer...
I have had similar problems in the past using my Roto-Zip on jobs. You may want to check the internal brushes in the machine have not been clogged with the dust from the ceramic tiles. The unit may have simply overheated from the stress of cutting the tile. This will also affect the brushes in the Roto-Zip. A can of compressed air may help clear any dust built up around the brushes. If they brushes are caked with to much dust, you may have to take the unit appart and manually clean the brushes. But, be careful because the brushes are spring loaded. Hope this information is helpful.
Aug 17, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
Was using a rz5 roto zip and i believe iy over heated and will not turn on again first use ever
Same thing happened to me, when I took it apart I found that one of the electrical connectors has broken cutting power from the unit.
Jul 31, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
My rotozip RZ20 keyless chuck will not open.
open the chuck and look in the center there is a screw allen type most times or a star screw in the middle that connects it to the drill shaft just tighten it up should work fine then!
Apr 27, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
4x4 Manual locking hub stuck in "lock"
What I have done in the past when manual locking hubs were difficult, is have a friend get in the vehicle and slowly roll backwards while I attempted to unlock the hub.
Feb 22, 2009 | 1995 Suzuki Sidekick
Bosch RotoZip Spiral Saw RZ10 - 2100 Logo
370 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
