Question about Sewing Machines
How do i slow down the speed on a consew 210 sewing machine
SOURCE: TIming Consew 210
what Brand sewing machine you got and model
Posted on Aug 27, 2008
SOURCE: I have a Consew 230
www.sewusa.com can provide a manual
Posted on Oct 09, 2008
  • 71 Answers
SOURCE: service manual for a consew 106rb
Hope this helps! Let me know if it not the right manual, and I will find you the correct one.
http://consew.marginspluslive.com/images/products/parts%20books/106R.pdf
Posted on Oct 31, 2008
Mimito7
  • 128 Answers
SOURCE: Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Posted on Apr 19, 2009
SOURCE: Need instruction manual for Consew 226R-1
Found manual on internet from company
Posted on Jan 04, 2010
Consew sewing machine 210 model slack stitch underneath, have put in new needle cleaned everything, oil level good, tension discs cleaned but still having dramas.
Assuming your top thread tension at no.4 or mid range, still not good, check your bobbin thread tension ok or not. If tight try reduce the tension. Problem persist, possibly bobbin case tension spring dirty or ageing.
Nov 05, 2013 | Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
How do you slow down the consew 206rb
You don't say if it is a clutch motor or a servo motor. They answer to your question is yes you can slow it down by either motor (usually a knob or switch) and by pulley. If you don't have a servo motor I would strongly urge you got contact Cobra Steve at leather sewing machine company (google it) Tell him you want one of the smart servo motors with needle position-er (needle up and down automatically)
His smart servo motors are also modified so they work very similar to home sewing machines... with graduated speed based on how hard you press the pedal.
But if you must and want to stick with a clutch motor... you might try this fellow's hack.
http://www.adafruit.com/blog/2007/11/08/hacking-an-industrial-sewing-machine-by-adjusting-the-clutch-motor/
Oct 25, 2012 | Consew 206RB
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
Hi, I just acquired a consew 206RB machine but not the manual. It starts very fast so,I'd like to know if it has a speed control. Thanks
I slowed mine down by replacing the pulley on the head with a larger pulley that I bought at the local hardware store. All of the internal parts slowed down by the same amount so after 20 years it still works fine.
I used a 6 inch pulley (about $10.00) with a 1/2 inch center hole. Finding the right size of drive belt was the hardest part of the whole operation.
There are only two screws that hold that pulley on. One of them is a set screw very near the small center hole that stops the pulley from spinning on the drive shaft.
I'm using a 206RB-1 for house furniture
Nov 17, 2010 | Consew 206RB
Have a Consew 206RB-1. Seems within the span of a few hours today that whenever I'm turning while sewing any material, it will drop a stitch. When sewing in a straight line, it's perfectly fine. Can't seem...
It is probably because you need to move slower when moving the material around, as otherwise the thread beneath will just stretch over and make a new stitch. just slow down loads and should work! this probably isnt the right answer but hope i may of helped! :)
Oct 28, 2010 | Consew 206RB
Can not start at a slow speed with foot pedal need to now how to adjust start speed
THE FOOT PEDLE IS NOTHING BUT A REASTAT. A REASTAT IS A WIRE WRAPPED AROUND A CONDUCTOR THE WINDINGS START OUT FAR APART AND GET CLOSER TOGETHER THE FARTHER YOU PUSH THE PEDLE DOWN . THE FAR APART WIRES ARE THE SLOW SPEED THE CLOSER ONES ARE FASTER SPEED
THESE WIRES WILL WEAR OUT OVER TIME OR CORRODE OVER TIME AND CAUSE THIS PROBLEM. TRY SOME ELECTRICAL CONTACT CLEANER AND SPRAY THE FOOT PEDLE INSIDE ANY WHERE YOU CAN AND LET DRY. MOST CONTACT CLEANERS ARE NONE CONDUCTIVE AND DRY IN MINUTES
Aug 15, 2009 | Consew 206RB
Consew 226 Speed
buy smaller motor pulley this will reduce machine speed
Jun 16, 2009 | Consew 226R-1
Consew
Sorry For being late this machine i cant find anything on this sorry
Aug 28, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
