Question about Consew Sewing Machines
HOW DO I SLOW DOWN A CONSEW 210 SEWING MACHINE
SOURCE: TIming Consew 210
what Brand sewing machine you got and model
Posted on Aug 27, 2008
SOURCE: I have a Consew 230
www.sewusa.com can provide a manual
Posted on Oct 09, 2008
  • 71 Answers
SOURCE: service manual for a consew 106rb
Hope this helps! Let me know if it not the right manual, and I will find you the correct one.
http://consew.marginspluslive.com/images/products/parts%20books/106R.pdf
Posted on Oct 31, 2008
riclap
  • 3 Answers
SOURCE: tacsew lu-563 sewing machine
Generally going to have to be addressing the drive motor, either substituting a lower speed clutch motor for the existing one, ie if you have 3000 rpm motor, then going to a 1725 rpm motor. Alternatively, selling the clutch motor and buying a servo motor instead, which should be available with a variable maximum speed control. The Sewquiet 4000 can select different speed ranges with the flick of a switch. If you already have a servo motor and it does not have a variable max speed, then switching the drive pulley on the servo motor to a smaller size should help
A more convoluted solution would be building a support under the table for a layshaft with different pulley sizes so that the motor could drive one pulley and then a smaller pulley on the shaft would drive the sewing machine. Not a bolt on solution but pretty cheap to do if you are good at fabricating.
Posted on Jan 01, 2009
Mimito7
  • 128 Answers
SOURCE: Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Posted on Apr 19, 2009
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Consew sewing machine 210 model slack stitch underneath, have put in new needle cleaned everything, oil level good, tension discs cleaned but still having dramas.
Assuming your top thread tension at no.4 or mid range, still not good, check your bobbin thread tension ok or not. If tight try reduce the tension. Problem persist, possibly bobbin case tension spring dirty or ageing.
Nov 05, 2013 | Sewing Machines
How do you slow down the consew 206rb
You don't say if it is a clutch motor or a servo motor. They answer to your question is yes you can slow it down by either motor (usually a knob or switch) and by pulley. If you don't have a servo motor I would strongly urge you got contact Cobra Steve at leather sewing machine company (google it) Tell him you want one of the smart servo motors with needle position-er (needle up and down automatically)
His smart servo motors are also modified so they work very similar to home sewing machines... with graduated speed based on how hard you press the pedal.
But if you must and want to stick with a clutch motor... you might try this fellow's hack.
http://www.adafruit.com/blog/2007/11/08/hacking-an-industrial-sewing-machine-by-adjusting-the-clutch-motor/
Oct 25, 2012 | Consew 206RB
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
How to thread a consew 7360R
There is below the link to the Instruction Manual for your Consew 7360R sewing machins.
Enjoy!
http://consew.marginspluslive.com/images/products/pdf10/7360r-rh-rbboth.pdf
Sep 02, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
Have a Consew 206RB-1. Seems within the span of a few hours today that whenever I'm turning while sewing any material, it will drop a stitch. When sewing in a straight line, it's perfectly fine. Can't seem...
It is probably because you need to move slower when moving the material around, as otherwise the thread beneath will just stretch over and make a new stitch. just slow down loads and should work! this probably isnt the right answer but hope i may of helped! :)
Oct 28, 2010 | Consew 206RB
Consew
Sorry For being late this machine i cant find anything on this sorry
Aug 28, 2008 | Sewing Machines
What parts do you oil a Consew 315R Sewing Machine?
Any part that moves and rubs Such as the needle bar , the presser foot bar, the linkage that moves the needle up and down, the bushings at the end of each shaft (Top and Bottom). All the red spots you see on the machine.
sewman7
Jul 09, 2008 | Consew 199R-2A Sewing Machine
Sewing Machines Logo
129 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
