Question about Whirlpool Duet GHW9150P Front Load Washer
Opening the soap dispenser
Don't see how to open the soap dispenser drawer on the whirlpool from load washer
  • Linda Williams
    Linda Williams Nov 28, 2012
    figured it out - there is no release or anything just needed to lift it slightly
F02 drainage problem. what seems to be the most common problem ?
Posted on Nov 28, 2012
  • 159 Answers
SOURCE: Whirlpool Duet Washer 8500 Dispenser Leaking
Ok try not to pull the dispenser too far out. When you pour the liquid detergent in the dispenser I belive it should say in the cup. For the shaking if the washer is not on a solid surface like a cement floor it will shake and walk if the floor is weak. Also make sure the delivery guys removed the 4 shipping bolts in the back. If the dispensor still leaks call for service bucause its new. Also some stores will exchange it if there is a problem within 30 days.
Posted on Jul 13, 2007
SOURCE: whirlpool duet washing machine
I work at Whirlpool, and we recommend a product called Affresh to help eliminate washer odor. Affresh washer cleaner tablets break up many of the residues that bacteria, mildew and mold grow on, and it removes them, leaving you a cleaner washing machine.
For a limited time, they’re running a promotion on whirlpool’s website that will get you free shipping on a 3 –pack of Affresh tablets! You just enter EAF822 as the promo code, and they’ll ship you the packet at no cost to you!
Posted on Aug 26, 2008
  • 9 Answers
SOURCE: Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Posted on Jan 31, 2009
  • 240 Answers
SOURCE: water leaking from the soap dispenser during rinse and spin cycle
use liquid instead of powder and always use HE detergent
Posted on Apr 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet washer leaking/pouring water out of
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Posted on Sep 27, 2010
When pushing the soap dispenser drawer it does not spring open any longer. Is there a way to fix this?
Re: Soap dispenser door not opening properly...(in case you still need to know)
You might want to use a small mirror (and flashlight) to see where the the spring assembly fits. Turn the rod facing towards you with the flat side up. It attaches at the rear, top left corner, near a small opening on the back wall (shaped liked the assembly). Fits into the "grooves". Apply enough pressure and you will feel it snap into place.
Dec 31, 2010 | Electrolux EIFLW55I Washer
My Whirlpool Duet washer is leaking from the
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not completely drain the water out of the soap dispenser. It is five years old
Jun 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking/pouring water out of soap dispenser
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport that is overflowing from the soap dispenser
Dec 03, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
We have a Kenmore frontloader pooring water from soap dispenser
Oct 16, 2009 | Kenmore 44102 Front Load Washer
Whirlpool Duet leaks soap from dispenser and side of machine at start of wash cycle
Oct 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Water doesn't drain in to the drum, it is over flowing out the soap slide out.Something is keeping it from flowing into the drum.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Mar 28, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Soap Dispenser won't empty
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Soap will not dispense
Feb 07, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
