The machine does not start as when trying to start the machine the blades are trying to turn
SOURCE: drive wheels not ternning
Tillers have a handle that you "squeeze to go". The handle activates a clutch, usually through a flexible cable. Does that handle offer resistance about halfway up as you squeeze it?
If not, that cable may have stretched a bit. Try adjusting the clutch by turning the nuts on the threaded sleeve where the cable comes out near the handle, until you get resistance when you squeeze the handle. The cable could also be broken, in which case adjusting won't help, but replacing the cable isn't expensive.
There's something else to check. Tillers have a pin to lock the wheels to the axle. It's right at the wheel hub. The pin can be pulled out to make it easy to move the tiller without running the motor. If you can push the tiller around easily with the motor off, then you may just have a missing wheel pin.
If it's not these simple things, it could be something worse like a problem in the transmission. If reverse works, but not forward, then it's probably the transmission, which is bad news. I hope it's one of the simple problems above.
Please rate if this was helpful, thanks and good luck!.
SOURCE: I have a troy-built rear blade tiller. It starts
Your belt is likely slipping. To adjust the belts, slide the block down that the roller on the forward/reverse lever uses to lock the tiller into forward. Use a 9/16" wrench to loosen the bolt on the backside of the block, then slide the block down a bit and retighten the bolt. If it's not the belt slipping, you've got transmission gear or bearing problems that could be costly to repair. I hope it's the simple adjustment.
SOURCE: MY TILLER HAS 4 ROUTATING BLADES IN THE FRONT,
under the housing where the pull cord is found is a latch type item with what they cal daugs, when you pull the cord the daugs fly out and catch into slots which will loch to start the engine, try some WD40 spray lube to free the daugs if this dosn't do the job you may end up getting a new housing or starter assembly
SOURCE: After a few weeks of
Sometimes the gas filter in the gas tank gets plugged. Here are some instructions that will help.
http://mantis.com/mantis-owners-manuals.asp Thank You for choosing FixYa.com and good luck.
