Question about Whirlpool Washing Machines
Whirlpool doesnt empty drum after washing
Wfw8300sw00 duet sport serial#hlt1690073
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Remove the bottom kick plate and clean the filter. Have some towels handy! There will be some water that will come out when you open the filter. Keep me posted.
Posted on Nov 28, 2012
  • 6 Answers
SOURCE: The motor does not engage in at all
The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
Posted on Jan 02, 2009
rylee_smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
SOURCE: My whirlpool duet sport washing machine has F-28 error
i have the same problem... and i got it fixed 3 times.. the frist time.. there was stuff stuck in the pump... but every time i go look in the pump.. theres nuthing and i still get f-23... good luck..
Posted on Mar 11, 2010
  • 901 Answers
SOURCE: I am looking for the service manual for the
Pl search through google search
Posted on Mar 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: My whirlpool duet sport washer WFW8300SW00 does not work properly
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
Whirlpool dues sport WFW8300SW00 is plugged. I've traced the plug to being inside the hose (AP3866284) that is above the pump motor and attached to the drum. How do I get at this part to remove an
Here is a link to my service manual for your Duet that will show you how to access it.
These manuals cost me a lot of money so if you are able to make any donation so that I may ad more manuals to help others, please do so. If you can't afford it no problem and enjoy the manual.
Oct 17, 2012 | Whirlpool Duet Sport WFW8300SW 3.4 cu. ft....
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
Whirlpool duet sport washing machile leeks out of dtergent area!!
the water is leaking out from the dispensor area??? sounds as if perhaps something has gotten down there blockig the waterwway, try removing the soap dispensor entirely and lookin towards the rear for a possibel obstruction
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi!
“F20” on display
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
F21 error code Model# WFW8300SW00 Duet Sport Washer
unfortunately there are no other pumps that you can put on the washer. You have to use the pump that is for the washer. A couple of tips though that you can go by with it is after every wash make sure to check the bellow boot for anything that may be stuck in it. That is the black rubber boot that goes around the drum and door. Socks and coins and under ware get in there and eventually get sucked down into the pump causing these problems. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need a part number
The part number is W10160252. You can order the part at sears.com . The price is 131.10
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
