Question about Epson Stylus 1400 InkJet Photo Printer
Black ink blobs, streaks, and dots
I can't get a clean print and it seems to be an issue with black. I've tried realigning the heads, cleaning the nozzles, I don't know what to do next.
    New Friend:
  • 4 Answers
R350 type my printer,not respont end error in display
Posted on Nov 28, 2012
Nandakishore
  • 304 Answers
SOURCE: Epson Stylus C88 won't print black ink
You have tried almost all the steps. You have to consult Epson Service Support. Don't try more the head can damage.
Posted on Mar 06, 2009
  • 10 Answers
SOURCE: epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Posted on Jan 01, 2009
gwbm
  • 353 Answers
SOURCE: Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Posted on Feb 01, 2009
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Posted on Mar 12, 2009
Remag1234
  • 387 Answers
SOURCE: my epson cx 6600 black ink not printing.i have
The Black nozzle is Clogged. There are several fixes, too long to write here. Go the website below, they have tools, cleaner, instuctions.
http://www.inkproducts.com/ink-store/
Posted on Jun 26, 2009
Horizontal White Lines
My 1st thought would be clean heads also. If ink is tanks only not heads take ink out and try cleaning heads with liquid cleaner available @ Staples or similar stores. Another fix might be to use alignment utility for your printers software; however before you do any of this if ink is old or nearly empty replace ink.
Jun 13, 2013 | HP OfficeJet V40 All-In-One InkJet Printer
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
When printing, print is has irregular & has white streaks through letters. Have tried "Print Head Cleaning" & "Print Head Deep Cleaning" several times and now printer won't...
you can flush the printhead on running water.
and have a mixture of ammonia and water solution. Soak the printhead and leave it overnight. This will unclogged residue in the printhead.
it will work again as good as new.
Jan 18, 2011 | Canon PIXMA iP3500 Printer
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Leaking magenta ink onto output HP 9180
Hi all. After running the clean heads and extended clean heads routine about 5 times i have resolved the issue. Took some time but all seems well now.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
Epson Stylus  1400 InkJet Photo Printer Logo
115 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
